I'm very close to make it work. I used EasyHID with the Descriptor find in that topic http://www.picbasic.co.uk/forum/showthread.php?t=2872 (curiously this link can only be found by making a search...) I've made some modifications but even with the original file I have the same problem.
Everything is OK compilation is done without any bug, the enumeration is also perfect (the PC really think a keybord is in). I've put a button and when I press it the letter "a" should be send. When I push the button it works but too much... I have "aaaaaaaaaaaaaaaaaaaaaa....." send endeless. My button works don't be worry I already test it.
I give the pbp code in attachment but I don't think the problem is inside. I also verified the Descriptor file and it looks like the parameter found in the USB.org files. If you have any idea it will be appreciate cause I think I've tried all but the right thing to do. Thank you very much.
