PBP 16F876A 2 Way Communication
Results 1 to 14 of 14
    dmugan's Avatar
    dmugan Guest
    Default PBP 16F876A 2 way Communication
    Thanks Mat and Ioannis,
    The HSERIN command now reads:
    HSERIN [char var byte]
    I still get the same error
    ERROR Line 38: Expected '['.
    Anything else I should try? Thanks everyone.
    Oct 2003
    holland
    There is al small misunderstanding.
    You should do this !
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 10
    adcVar VAR WORD
    char VAR BYTE
    TRISA = %11111111
    ADCON1 = %10000010
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLOERR 1
    PAUSE 005
    If PIR1.5 = 1 THEN
    HSERIN [char] 'and than this
    HSEROUT [DEC adcvar, 10, 13]
    ADCIN 0, adcVar
    PAUSE 50
    GOTO main
    dmugan's Avatar
    dmugan Guest
    Default PBP 16876A 2 way Communication
    Mat,
    Thanks a million. The program now compiles ok, but it seems to hang during execution of the program. I have tried re-arranging the order of the instructions, but so far no luck. I will appreciate more suggestions
    Sep 2005
    Campbell, CA
    I'm going to tell you to READ THE PBP MANUAL now.
    Charles Linquist
    a little typo error...
    should be
    DEFINE HSER_CLROERR 1
    dmugan's Avatar
    dmugan Guest
    Default PBP 16F876A 2 Way Communication
    Thanks to everyone, and a second time to Mister E for finding my typo. It now works like a charm! Have a great day!
  1. 2 PIC, serial communication
    By lightgreen in forum Serial
    Last Post: - 21st November 2009, 16:20
  2. Help with 2 way communication
    Last Post: - 22nd April 2007, 10:11
  3. Microcontroller with 2 way paging application problem
  4. PIC 2 PIC communication
    By Mario in forum Forum Requests
    Last Post: - 28th April 2006, 02:56
  5. hpwm more than 2 ch possible in pbp?????????
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 10th March 2006, 08:28
