Hi DynamoBen,
Ok, but how make it in picbasic pro?
I send three variables with eight bits (byte) each, for another pic.
I don't know how to implement it.
Thanks, Daniel
Hi DynamoBen,
Thanks, Daniel
What you are asking is very general, I'm not sure what would work best for your application. You will have to choose a method that works for you. The best I can do is suggest things that might work, you will have to sort through the details or each option. If you have specific questions about a specific method we should be able to help you out.
Have you searched the forums and read through other discussions on this topic? If so that should give you a start. Below are some threads that might help spark some ideas.
http://www.picbasic.co.uk/forum/sear...d=146892&pp=25
http://www.picbasic.co.uk/forum/show...light=checksum
