Rc signal help
Results 1 to 40 of 43
Thread: Rc signal help
    Ok so here it is Im stupid was the main problem. Somehow I figured that the signal would just come pouring out of that little white wire without any ground to the signal cable... Once I got over that blonde moment everything fell into place. The code below could be done a lot better and some saftys put in for wild RC signals but I wanted to get out some working code.
    Basically by moving the stick back and forth it will figure out whats the max high and low and then accept anything thats about 1/3 of that in that direction. Now that its clear as mud here is the code
    '12F675
    @ __CONFIG _INTRC_OSC_CLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    OPTION_REG.5 = 0                                                       ' clock source internal
    Pulselen   var Byte                                                 ' Pulselen can be 0 - 255, 100 = 1 ms, 200 = 2 ms
    Init       var Byte                                                 ' Init used to flash LED
    HighCode   Var Byte
    LowCode    Var Byte
    clear
    highcode = 0 ' setup vars to be changed
    lowcode = 200 ' setup vars to be changed
    Input GPIO.3                                                           ' set pin 5 to RX signal
    ReadPWM:
       PulsIn GPIO.3, 1,Pulselen                 ' pin 4 - read high pulse length, times out after .65535 seconds
    If pulselen > highcode then Highcode = Pulselen ' make sure highcode is at full throw This will avoid having to go though a setup
    If pulselen < LowCode and Pulselen > 50 then Lowcode = Pulselen ' make sure lowcode is at full throw This will avoid having to go though a setup
    if (Pulselen + 20) >= highcode then
       For Init = 1 To 6
          High GPIO.1
          pause 60
          Low GPIO.1
          pause 60
       Next
    If (Pulselen - 20) <= LowCode Then
          High GPIO.1
          pause 3000
          Low GPIO.1
          pause 200
       GoTo ReadPWM
    malc-c's Avatar
    malc-c Guest
    Yup - works here too - using a JR X3810 transmitter and cheap and chearful GWS RX
    We got there in the end
    malc-c's Avatar
    malc-c Guest
    I've changed your code a bit to make a simple RC Switch that turns on GPIO.1 in real time (ie activate the switch on the TX and the LED lights or goes out)
    I've also removed some parts that are not needed (input GPIO.3 for example as PULSIN automatically makes the pin an input)
    '12F675
    OPTION_REG.5 = 0
    Pulselen   var Byte
    HighCode   Var Byte
    LowCode    Var Byte
    clear
    ReadPWM:
    if (Pulselen + 20) >= highcode then High GPIO.1
    If (Pulselen - 20) <= LowCode Then low GPIO.1
    GoTo ReadPWM
    Good result for the end of the day.
    There ya go thanks for the help didn't notice the 2nd page or would have replied sooner
  1. Replies: 24
    Last Post: - 1st December 2009, 08:01
  2. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 16:28
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Rc PCM signal Read (Help)
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 03:37
