Rc signal help
Results 1 to 40 of 43
Thread: Rc signal help
    Hi, Gecko
    Some little gags here and there ... but try it !!!
    '12F675
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF ' clock source internal
    OPTION_REG.5 = 0
    DEFINE PULSIN_MAX 2500
    DEFINE OSCCAL_1K 1
    CMCON = 7 'Tout digital pour 12F675
    ADCON0 = 0 'ADC off "
    ANSEL = 0
    VRCON = 0
    Pulselen var Byte ' Pulselen can be 0 - 255, 100 = 1 ms, 200 = 2 ms
    Init var Byte ' Init used to flash LED
    Compte var Byte
    In var GPIO.3
    Led var GPIO.1
    Clear ' set all variables = 0
    TRISIO = %001000
    High Led
    ReadPWM:
    PulsIn In, 1,Pulselen ' pin 4 - read high pulse length, times out after .65535 seconds
    If Pulselen < 80 OR Pulselen > 220 Then
    Pause 15
    Compte = Compte + 1
    IF Compte // 16 THEN
    Pulsout Led, 10000
    Else
    HIGH Led
    GoTo ReadPWM
    I'll do better next time ...
    PS: ... breadboard verified .... Yess !!!
  1. Replies: 24
    Last Post: - 1st December 2009, 08:01
  2. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 16:28
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Rc PCM signal Read (Help)
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 03:37
