Rc signal help
Results 1 to 40 of 43
Thread: Rc signal help
    Your program jumps to the same location whatever the pulsewidth is:
    ReadPWM:
       PulsIn GPIO.3, 1,Pulselen                 ' pin 4 - read high pulse length, times out after .65535 seconds
       pause 15
       If Pulselen < 50 Then GoTo Blink     '<----HERE......
       If Pulselen > 50 Then GoTo Blink     '<----and HERE.....
       GoTo ReadPWM
    Change the the second If statement to
    If Pulselen > 50 then Goto Solid
    HTH
    /Henrik Olsson.
    Yea that was an accident when I retyped to simplify the code but its fixed now and still doesn't work.
    I also added this
    CMCON = 7 ' PortA Digital inputs
    I think this chip starts as analog or something still no help.
    The 'F675 has one comparator AND an A/D converter.
    The comparator is turned off with CMCON=7 and the the pins for the A/D is set to digital only with ANSEL=0.
    However....
    You're using GP3 for your input and that pin is not connected to either the comparator or the A/D so none of the above should really matter but I'm not sure. GP3 is however the MCLR pin and it seems you have a typo in your config setting. I THINK it should be MCLR_OFF and not MCLRE_OFF. - try it.
    Also, you're using a byte-size variable to store the pulsewidth, try switching that to a Word instead.
    /Henrik Olsson.
    Quote Originally Posted by HenrikOlsson
    However....
    /Henrik Olsson.
    I tried swapping back and forth on ANSEL and CMCON neither seem to make a difference. Also when I change to MCLR_OFF it errors and will not even compile.
    I tried using word as well no luck.
    Default No problem w/ MPLAB
    Hi, gecko
    No problem compiling with MPASM 7.41 and PbP 2.46a ...
    Error [ 118 ] is to forget when using @ __config
    May be add END ... at the end !!!, but that's not compulsory ( good habit then ... )
    Quote Originally Posted by Acetronics
    Hi, gecko
    I'm not sure I understand what your saying exactly but.
    '12F675
    @ __CONFIG _INTRC_OSC_CLKOUT & _WDT_OFF & _MCLR_OFF & _CP_OFF
    OPTION_REG.5 = 0                                                       ' clock source internal
    CMCON = 7
    ANSEL=0
    Pulselen   var word                                                 ' Pulselen can be 0 - 255, 100 = 1 ms, 200 = 2 ms
    Init       var word                                                 ' Init used to flash LED
    Clear        ' set all variables = 0
    Input GPIO.3                                                           ' set pin 5 to RX signal
    ReadPWM:
       pause 15
       If Pulselen < 50 Then GoTo Blink           ' no signal  -> blink led
       If Pulselen > 75 Then GoTo solid           ' signal  -> Solid led
       GoTo ReadPWM
    Blink:
       For Init = 1 To 3                                                   ' blink led 3 times
          High GPIO.1
          pause 200
          Low GPIO.1
          pause 200
       Next
     GoTo ReadPWM
    Solid:
          High GPIO.1
          pause 3000
          Low GPIO.1
          pause 200
     GoTo ReadPWM
    fails compile saying
    error 113 Symbol not previously defined (MLCR_OFF)
    When I use _MCLRE_OFF instead it compiles with no error.
    malc-c's Avatar
    malc-c Guest
    Just a few comments from my basic understanding of RC
    Input GPIO.4                ' set pin 3 to RX signal - changed as GPIO3 is not ideal
    ReadPWM:
       PulsIn GPIO.4, 1,Pulselen    ' pin 3 - read high pulse length, times out after .65535 seconds
       pause 15
       GoTo ReadPWM
    If you read the comments for pulselen it states that 100 = 1ms and 200 = 2ms, but your if / then statement states that if its less than 50 go blink. If you are monitoring a "normal" PPM signal from a receiver, the pulse length will be around 1ms for low stick and 2ms for full stick, with 1.5ms at centre. So even at low stick the signal will be 1ms or a pulse length of 100, it will never be lower than 50, and this the code will never jump to flash.
    I too had to change the config line to MCLRE_OFF for it to program without error
    EDIT:
    Oh and one other thing that may be causing the problem is that the RX will be sending the PPM pulse every 20ms, so you will need to get the timing right so that the pin is checked for a pulse at the right time. According to code it times out after .65535 seconds, maybe you need to make this time out after 20ms so it loops back round. Most of my experiments with other languages used the pre-scaler to get the timer to roll over at the desired timing if a pulse wasn't present. Maybe some of the more experienced guys can jump in here as I don't know if PBP features this option ?
  1. Replies: 24
    Last Post: - 1st December 2009, 09:01
  2. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 17:28
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Rc PCM signal Read (Help)
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 04:37
