Can It Be this SIMPLE? (the Off-Topic continuation)
Results 1 to 40 of 64
    When I meant a Time-Delay Relay on the turbo switch, I meant that the Relay contacts were is SERIES with the switch and not in parallel with it. i.e., until the Relay threw, the turbo switch was out of circuit. Only AFTER the Relay closed, only then the turbo switch could be pressed if desired.
    This way, the Time-Delay Relay is simply connected across the Motor, so when power is applied to the motor, the Relay then times and then after a preset time period closes it's contact enabling the turbo button if so desired. If you take power off the motor, the Relay drops out ready for a new timing cycle.
    A couple of transistors, a Capacitor and a splattering of Resistors and you've got your circuit for about $1, no PIC, no software, and pretty much supply voltage independant with no worries about having to generate a clean 5v supply for the PIC.
    Apr 2005
    Melanie,
    Thanks for explaining what you meant. My first reaction was to ask for a schematic,
    but I want to stir some brain cells and actually THINK about what it is you are describing.
    (Amazingly Sad how rusty I am on this stuff these days, if you don’t use it you LOSE it.)
    I’ll have to sit down with pen & paper to see what I come up with before I come BEGGING
    and have to bother you for a schematic. 8-)
    Mike_L
    Cool O K Dad
    When my Daughter was about that age I bought her a Suzuki JR50 motorcycle which she rode exactly once. Too much power and she bailed off never to ride again. So here's a suggestion: install a 1/4 inch headphone jack on the rear of this vehicle, break the power connection and wire it through the jack. the plug that mates gets a string attached to Dad or Grandpa. short the inner to the outer conductor of the plug. when it's plugged in he has power, if it gets away from him, the plug pulls out and it stops. You could get creative and use a shorting type jack so instead of stopping it switches to low power. I doubt
    Dale Earnhart JR's. first ride was souped up very much.
    RULE 1, SAFETY FIRST (Especially with kids)
    RULE 2. Go back to rule 1
    Lightbulb a little idea
    Hi, Joe
    I see something ... a DC motor Torque is a major function of the drawn current ...
    soooo, limiting the Max current is a fair way to achieve your goal.
    Now how ??? ... Mosfets have an internal ON resistance ... so, using PWM, just measure the D to S voltage, during the ON state ( 100% will also work ...), exactly as with a shunt ...
    A simple comparator will short the gate voltage to ground if overcurrent... and allow to easily trim the limit.
    That's what used on Power speed regulators for Electric models ...
    now, you DO NOT have PWM aboard ... so, just sample D/S Voltage , say @ 500 hz to 3 KHz ( match to the motor ). Limitation will then be smooth enough.
    Using a PIC to slowly automatically increase the PWM rate will add the soft start function ... and you've what you want
    AND the MOTOR is SAFELY DRIVEN ...
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 11:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 21:30
  5. Replies: 4
    Last Post: - 7th September 2005, 15:11
