Visual Basic 6 & Access 2000
Results 1 to 34 of 34
    Italy
    Under most circumstances, SendKeys is not recommended in a production environment.
    This is because the keystrokes are processed by whichever window is currently active
    on the desktop. Obviously this will cause unpredictable behavior in case another app
    receives the focus while your code is processing the Sendkeys statement.
    If you're unlucky, the keystrokes sent to application may cause all documents
    to be deleted or the hard drive to be formatted.
    So try to avoid Sendkeys at all cost.
    Best regards,
    Luciano
    Luciano, The whole reason for this application is to send keystrokes to an application.
    Keith, That's how the Help file does it, I had shrunk it down a bit for testing.
    I was hoping there was a sort of 'list' feature of running applications that I could scroll through; something like ALT-TAB. But now that I think more about it, similar applications make the user select the executable (like the Profiler for the Logitech wheel). By forcing focus on a selected executable, I reduce that danger that Luciano brought up.
    I ended up storing the executable, at least it works.
    Any idea why this is seen by a game:
    SendKeys "{F3}", False
    But this is not:
    SendKeys "{LEFT}", False
    The Help file lists the Left Arrow as a special character just like F3, but it doesn't work for some reason.
    Italy
    Games use DirectInput. (DirectX).
    Best regards,
    Luciano
    Yes, but games also use keyboard input.
    I found several good tutorial links on a gaming site:
    http://www.vbtutor.net/vbtutor.html
    http://cuinl.tripod.com/tutorials.htm
    http://www.vbcode.com/
    http://www.planet-source-code.com/
    Not sure if they were mentionned above.
    One guy in those tutorials recommended using the SendInput feature instead of the "basically broken" SendKeys.
    I'm starting to see what people have moaned about MS products. Most of the links I've read relating with SendKeys says that it is not reliable, if it works at all.
    This place describes using a more flexible keyboard API:
    http://www.vbaccelerator.com/home/VB...PI/article.asp
    Still reading, how it's understandable.
    Italy
    Normal windows programs
    When a key is pressed, the keyboard driver passes the keystroke
    to Windows and the message is saved in the system message queue.
    Windows then transfers the message from the system queue to the
    queue of the program with the "input focus" where the keystroke
    is then processed.
    Games using DirecX
    DirectInput (see DirectX) works directly with the keyboard driver.
    So when you play, the game does not get keystrokes as a normal
    Windows message.
    Be aware that posts in forums can be very old. (Not about VB6 SP6).
    Also most of these post are written by people like me and you.
    Best regards,
    Luciano
  1. Replies: 5
    Last Post: - 24th August 2006, 22:59
  2. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  3. Visual Basic 6 and Pic com
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 06:21
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
