Visual Basic 6 & Access 2000
Results 1 to 34 of 34
    Mar 2005
    Iowa, USA
    Lightbulb What about INI files?
    Quote Originally Posted by Demon
    What techniue would you use to store a "cookie" in VB? I set a drive, folder and filename in a form and I'd like to save that value between sessions.
    I use INI files... that's mainly what they're for. Here's a module I use for them. Just add it to your project and use WriteProfileString & FetchProfileString functions to write and read to the INI file.
    'ModINIFunctions.bas
    Option Explicit
    Private msWinPath As String
    Private mlRetLength As Long
    Private msDirReturn As String
    Private Declare Function GetPrivateProfileString Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
    Private Declare Function GetWindowsDirectory Lib "kernel32" Alias "GetWindowsDirectoryA" (ByVal lpBuffer As String, ByVal nSize As Long) As Long
    Private Declare Function WritePrivateProfileString Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long
    Public Function FetchProfileString(ByVal sINIFile As String, ByVal sApp As String, _
                                       ByVal sKey As String, Optional DefVal As Variant) As String
    'Purpose: Reads information from a *.INI file
    'Inputs:    sINIFile    String      Name of file INI file including path
    '           sApp        String      Name of application section in INI file
    '                                   Example [My App]
    '           sKey        String      key name under application section
    '           DefValue    String      default value of key
    '           Example   [MyApp]
    '                     MyKey = MyValue
    'Assumptions:
    '           1.  Windows API GetPrivateProfileString function declared with the following statement in the
    '               Private Declare Function GetPrivateProfileString Lib "kernel32" Alias "GetPrivateProfileStringA"
    '                   (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
    'Effect:   None
        Dim sReturn As String
        Dim sDefVal As String
        Dim mlReturnLength As Integer
        If IsMissing(DefVal) Then
            sDefVal = ""
        Else
            sDefVal = CStr(DefVal)
        End If
      '  msDirReturn = Dir(sINIFile)
      '  If msDirReturn = "" Then
      '      mlRetLength = WritePrivateProfileString(sApp, sKey, sDefVal, sINIFile)
      '  End If
        sReturn = String$(255, 0)
        mlRetLength = GetPrivateProfileString(sApp, sKey, sDefVal, sReturn, 255, sINIFile)
        FetchProfileString = Left$(sReturn, mlRetLength)
    End Function
    Public Function WriteProfileString(ByVal sINIFile As String, ByVal sApp As String, _
                                       ByVal sKey As String, ByVal sVal As String) As Boolean
    'Purpose: stores information to a *.INI file
    '                                   Example [My App]
    '           sValue      String      value of key
    '           Example   [MyApp]
    '                     MyKey = MyValue
    'Assumptions:
    '           1.  Windows API WritePrivateProfileString function declared with the following statement in the
    '               Private Declare Function WritePrivateProfileString Lib "kernel32" Alias "WritePrivateProfileStringA"
    '                (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpString As Any, ByVal lpFileName As String) As Long
    '           2. if *.INI file does not exist this function will create the file
    'Effect:   Contents of *.INI file
        mlRetLength = WritePrivateProfileString(sApp, sKey, sVal, sINIFile)
    End Function
    Here's an example of reading in the language value under the Section named SAP in the Pack.ini file.
       PstrLang = FetchProfileString(App.Path & "/PACK.INI", "SAP", "LANGUAGE", "EN")
    Here's an example of how the data in the INI file would look.
    ;comments use the semicolon
    ;In this example parameter sApp =  SAP
    ;parameter sKey = Language (there can be multiple keys under one app parameter)
    ;The value returned to PstrLang in the example above is EN
    [SAP]
    LANGUAGE=EN
    This is a really useful way of storing different user preferences etc.
    Another method would be writing and reading to the registry. But I'll let you explore that option.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Thanks, that looks great.
    I'm not too keen on writing to the registry.
    EDIT: Are you sure about this statement?
    Why read the INI file to find sValue if you are providing it in the statement? This would look more like a Write statement no?
    This one is really off-topic.
    I'd like to copy an Access MDB file from within VB6. I don't even know where to start looking for this. I figure this could be some sort of batch file like we used to be able to do in DOS.
    EDIT: Hmmm: http://builder.com.com/5100-6373-1050078.html CopyFile feature, interesting.
    I found this:
    FileSystemObject.CopyFile "c:\mydocuments\letters\*.doc", "c:\tempfolder\"
    But I'm stuck on how to define that FileSystemObject.
    EDIT: Found it, I needed to add a Reference to Microsoft Scripting Runtime (scrrun.dll).
    Mar 2005
    Iowa, USA
    Look at the FetchProfileString function. You have to provide a default value in this call, then it gets overwritten with what's in the INI file.
    Ryan Miller
    Default Select Where
    How do we point to a VB6 public variable from within a SELECT statement?
    Set rsProfile = dbProfile.OpenRecordset("SELECT * FROM tblProfile WHERE ptrMenu = ptrCurrentMenu")
    Both ptrMenu (primary key) and ptrCurrentMenu are defined as LONG, but it only works when I hardcode a 1 instead of ptrCurrentMenu.
    EDIT: Found it in Programmer's Heaven, thanks Steve: ("SELECT * FROM tblProfile WHERE ptrMenu = " & ptrCurrentMenu)
    Default Null not a null
    I would have expected this IF statement to trap a Null, but apparently it doesn't work that way. The execution fell right down to the ELSE and executes the next statement. Any idea how to do make it work?
    Feb 2003
    Try "vbNull" instead. (Cant test as I dont have VB on this machine!)
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Italy
    Use the Visual Basic function IsNull().
    Best regards,
    Luciano
  1. Replies: 5
    Last Post: - 24th August 2006, 22:59
  2. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  3. Visual Basic 6 and Pic com
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 06:21
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
