MCLoader & XPort
Results 1 to 40 of 45
    Mar 2006
    China
    Default It seems to work
    ifdef MAKE_LOADER
    LIST
    ORG 60160 ; type the adress for loader here
    NOLIST
    I added this Define in the LIB file and changed in my code to :
    DEFINE MAKE_LOADER 1
    and it works just fine. Now we don't have to hijack any other defines. So now we have a new DEFINE in PBP.
    If someone brilliant can find a way to send the address variable from PBP it would be great. I would like it to look similar to the:
    DEFINE RESET_ORG 64 where you include the value to be compiled.
    Like:
    DEFINE MAKE_LOADER 60160
    then there would be no need to change in the LIB file if you wanted an other address for the loader. Is that possible????
    /me
    Jumper,
    I made the .lib modification and modified your code to read back 16 memory locations starting at 60106. Data coming back from the read is all FF's, so it looks like there's no program located there.
    Comments?
    Joe
    DEFINE MAKE_LOADER 1 'Code will begin at 60160
    DEFINE HSER_RXSTA 90h
    define HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    define OSC 8
    OSCCON = $FF
    TRISB=%00111111
    TRISC=%10111111
    RB6 var PORTB.6
    RB7 var PORTB.7
    TX Var PORTC.6
    RX Var PORTC.7
    I VAR BYTE
    x var byte
    Flash var word
    Temp var word
    Goto INIT
    jump_back:
    'Flash=64
    'READCODE flash, temp 'Read the value at Flash adr
    'IF temp=$FFFF then STOP 'If it is $FFFF we have no application code in the PIC so STOP
    '@ GOTO 0x0040 'Start application
    'Here we decide if we should enter the Loader or not receiving a byte.
    INIT: Pause 200 'wait for things to settle
    Rb6=1 'indicate we are waiting for a character
    HSERin [x] 'if nothing after 5 sek go to jump_back
    if x="L" then
    PAUSE 100
    Goto Loader
    ENDIF 'If it is what we want to get then enter the laoder
    goto Jump_Back 'everything else jump_back
    Loader:
    FOR I = 0 TO 15
    READCODE (60610 + I),X
    hserout [$0D, $0A, ":", HEX(X)," "]
    NEXT I
    RB7=1 'Indicate we have entered the Loader
    RB6=0
    pause 200
    'Here we can recieve new data and write it to the FLASH
    'Erase before writing and write full blocks 64 bytes
    goto Jump_Back 'When finished goto
    Mar 2006
    China
    Default Hmm yes
    Check this part:
    FOR I = 0 TO 15
    READCODE (60610 + I),X <--------------- wrong
    NEXT I
    should be READCODE (60160+i),X
    But there is something else too, I need to check some things..... gimme half an hour
    /me
    Jumper,
    Well, while I fail to see any syntactical or other error in the way I wrote the line, I did cut-paste your suggested line into my program - no change
    Am I failing to understand something about how READCODE works, or is there no code at the memory locations where there should be code?
    Joe
    Mar 2006
    China
    Default Hmm MPLAB plays tricks with me
    Try the original HIJACKING way since I couldn't get it to work with our own DEFINE the second time I tried it.
    If you are using MPLAB you can look under view and program memory to see what your code looks like.
    Try the original approach:
    1: Change the LOADER_USED line in the LIB
    2: DEFINE LOADER_USED 1 in your code
    3: Compile
    4: Check program memory, there should be code in position 0 and 2 then FFFF until $EB00
    Syntax in PBP can be a little bit tricky. Some functions don't really like that you have a formula as argument. They want to have a WORD or BYTE only.
    /me
    Mar 2006
    China
    Default Compile results from your file
    This is with the DEFINE LOADER_USED in the lib file like this
    ifdef LOADER_USED
    LIST
    ORG 60160 ; Own loader address
    NOLIST
    Any luck now??
    /me
    Jumper,
    It seems like that's better. Here is dump result:
    :4
    :0
    :9E
    :AA
    :FD
    7
    :AE
    :50
    8
    :80
    :E1
    :EF
    :75
    :F0
    :E9
    :50
    But we should be able to do this with a custom DEFINE, no??
    Joe
  1. xport code, have example, confused though
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 19:59
  2. Bootloader and Instant Interrupts Atn:_DT_
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 16th May 2007, 01:59
  3. McLoader and 18F2580
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 12th February 2007, 06:20
  4. xport + connecting 2 networks
    By rf_xport in forum General
    Last Post: - 12th July 2006, 06:26
  5. Has anyone used the Lantronics Xport
    By octavio bru in forum mel PIC BASIC Pro
    Last Post: - 14th September 2004, 11:51
