Need CRC for RF PIC2PIC Bit arrayed interface
Results 1 to 11 of 11
    Sep 2005
    Question Need CRC for RF PIC2PIC Bit arrayed interface
    Hi!
    I want to build a RC model encoder/decoder (PIC to PIC@4Mhz) interface.
    On the transmitter side I've Frame[99] Bit array set of 10bit ADC datas to transmit.
    And I need a simple but reliable CRC for it.
    I dont want to waste bandwidth with like manchester coding.
    I prefer to do the job with more processtime like XOR-ing.
    How do i treat the Bit array like a long Bin number? (or I've to XOR-ed by one by one?)
    How do i add the CRC checksum to the array? (add-it, or append it)?
    The calc must be loop driven not table driven.
    If it is possible no shifting.
    How can i send/rec this array via Serin2/Serout2?
    an idea:
    Data in: Frame[99]+Checksum
    CONST onboardpolynomial = ....(bin array)
    x= (Frame[99]+Checksum) XOR onboardpolynomial
    if x =1 then goto error
    Thank you!
    Jun 2005
    Wisconsin
    A while back I did a wired project that just used a byte add error checking method.
    Add each byte to the last and store the sum in a byte sized variable:
    RX var byte[10]
    CHKSUMCALC var byte
    For Cnt=0 to 8
    HSerin 2,No_Data,[RX[CNT]] ' Buffer bytes to RX
    CHKSUMCALC = CHKSUMCALC + RX[CNT] ' Calculate the checksum
    Next Cnt
    Sep 2005
    Thx for your reply.
    But I read this:
    http://www.repairfaq.org/filipg/LINK....html#CRCV_002
    And i realised that summing is not so reliable like dividing.
    Does anyone know an easy Modulo-2 PICbasic arithmetic algorytm?
    May 2006
    Del Rio, TX, USA
    Default Another approach...
    Here is a ECC idea based on hamming code used for flash memory. It may be something you can apply to your situation. It has the advantage of being able to correct a single bit error, in addition to detecting multiple bit errors.
    Hamming Codes for NAND Flash Memories.pdf
    I have some ideas about how to implement this if you think it would be useful in your situation. The bigger the data packet, the more efficient the technique, but the more likely, in a noisy environment, that you will have more than one single bit error, and then be required to retransmit. Here is an example of one way you could use this: Send 6 * 10 bit ADC values + 12 bits of ECC for a total of 72 bits (9 bytes) of data. Since you are using only 60 of the first 64 bits, the top 4 ECC bits could be loaded into the 4 bits not used by the ADC values. When calculating the ECC, those 4 bits could always be 0, then filled with the ECC values before transmission. At the receiving end, the ECC values are replaced with 0s again before the ECC recalculation.
    I have played with this a little bit on 256 Byte (2048 bit) data packets, so I might have some code you could use as a starting place.
    HTH,
    Sep 2005
    I think its much more simple to use CRC rather than ECC.
    If a frame falls the CRC test, and its ignored, its loose just a ~12mS time.
    Then it will automatical sendout the previous good data to the servo.
    Here is a way to complex packet oriented Futaba transmision with 1bit error
    tolerance. http://graphics.tudelft.nl/~wouter/p.../pasman03k.pdf
    more ECC: http://en.wikipedia.org/wiki/Error_detection
    Is the Serin2/Serout2 reliable on 628A@internal 4Mhz?
    Or I must choose the pulseout/pause on TX and RX: Pulsin 1/Pulsin 0?
    The transfer rate is 5kbit/sec->5Khz, period time: 0,2mS
    The ADC is MAX148 10bit 8ch internal (or ext) clock (max 2Mhz),
    SPI interface.
    After I send the control Byte to its input.
    It starts the conv, then it sends out(shifts out by its clk) the selected
    channel value. Can I catch this data with something else than pulsin 1?
    I want to apply this in PICbasicPro
    http://ww1.microchip.com/downloads/e...tes/00730a.pdf
    anyone done this before (not the table driven code)?
    Thx
    Aug 2005
    The manual for the SNAP protocol describes a simple CRC method on this site. http://www.hth.com/snap/
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by mrx23
    Haven't used that chip, but see this post by Melanie on just that issue. YMMV.
    SPI interface.
    You should use PBP's SHIFTIN/SHIFTOUT with a SPI interface. No experiance with that particular ADC, but lots of folks (myself included) use SHIFTIN/SHIFTOUT with great success. You have to choose the correct "mode", but then it works a treat.
    Also, unless there is some unkown reason, why not select a PIC with ADC on board? Its surely going to be cheaper than the seperate MAX ADC, and no comm hassle. Lots of options to choose from: A quick search yielded 134 with 8 or more 10 bit ADC Channels.
    Sep 2005
    Thx, I will try the shifting.
    I choosed the Max 148 ADC becouse its free
    You can order sample www.maxim-ic.com
    The other reason:
    I want minimal pin usage for SPI, so the rest of the PIC pins
    can be used for Switches.
    Can I tied the CS pin (on ADC,chipselect,activ low) to directly to the ground?
    I just use one ADC chip.
    Thanks for this link: http://www.hth.com/snap
    I'll read it.
    Is this code correct? Do I have to care about stop bits?
    Or its just automatic (and hidden)?
    ' -----------------------[ Transmitter ]--------------------
    MultipleBites var Bit[60]
    MultipleBites[0]=0
    MultipleBites[1]=1
    MultipleBites[2]=0
    MultipleBites[3]=0
    MultipleBites[4]=1
    Serout2 pin,Baud,[str MultipleBites]
    ' ------------------------[ Receiver ]-----------------------
    Serin2 Serpin,Baud,[str multiplebytes\60]
  1. Dallas CRC8 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 8th May 2018, 19:07
  2. Bits, Bytes Words and Arrays
    Last Post: - 14th June 2016, 08:55
  3. Doubt with interrupt on change
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 16:22
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
