Cleaner code
Results 1 to 3 of 3
Thread: Cleaner code
    Default Cleaner code
    Can I make this cleaner? (works but its orrible!)
    z=1:y=1
    loop:
    SERIN portb.7,t1200,1000,timeout,combuf(z)
    z=z+1
    if z<87 then no_time_out
    timeout:
    y=0 ' flag that a timeout has occured IE end of data stream
    no_time_out:
    if y>0 then loop
    What would be better is
    for z=1 to 90
    next
    BUT the problem is I dont want to timeout 89 times if only 10 bytes is in the stream.
    Is their no command to read the serial into the byte array without looping, I'm worried it may not be fast enough if running a 4mhz crystal, I have lowered incoming data to 1200 but its then a bit slow, I'm shocked my dirty code kept up.
    f_lez, Why don't you use the STR modifier and if you know the data stream will be terminated with a constant character like a CR or LF then use one of them as a string terminator. That way you can terminate the string load early if lass data is entered. It's in the book......
    STR ? never heard of it !
    But I have changed the code some, I was worried that if I did something like this
    for n=1 to 10:serin wanted data(n):next
    for n=1 to 10:serin garbage data(n):next
    I thought I may miss a byte between statements, but I'm not, I suppose I'm just lucky or the codes just fast enough to keep up at 1200 baud.
    I guess I should have used the skip command but once again I cant seem to win the battle of the syntax when also using the wait command, can they not be used in the same instance?(anyone!)
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  3. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  4. Making Program Code Space your playground...
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
