Capacitor Measurement
Results 1 to 11 of 11
    Aug 2005
    Houston, TX
    Default Capacitor Measurement
    I saw an article in "Nuts & Volts" about a capacitor test device based on the discharge time of a capacitor. It occurred to me that the pot command would work in the same manner, and be much easier to assemble.
    With a 16F84A chip, I gave it a try, and it works, within limits, very accurately. I have an old Heathkit Capacitor substitution box, and my bread boarded effort is dead on from 100pf to 1uf.
    Anything below 100 pf returns 0, even with a 10meg discharge resistor.
    Above 2.2uf, I get a return, but it has no relationship to the cap's value. A 220uf cap might return 90uf, while a 47uf might return 148. I tried discharge resistors as small as 1 Ohm. Any return is useful, as open and short both return 0, but I would like to get a measurement over 2.2uf. And I would like to get a measurement below 100pf as well.
    I tried adjusting the prescaler, but it had no effect on my results. I am using a 4mHz resonator. Perhaps a faster clock would help the low end?
    For caps from 2.2uf - .001, I am using a 1k discharge resistor and a scale of 40. For 1000pf to 100pf, 20k and scale at 255.
    I suspect that internal resistance of the high value electrolytic affects their discharge curve in a way that confuses the chip. I get better results with tantalum caps, but they are still off 50 - 100%. And, perhaps any charge on a very small cap is lost during the time the chip switches from charge to measure.
    The author of the article claims better than 1% accuracy, 1pf to 999uf, but I wonder.
    The program is attached. I will provide a schematic when I draw one if any are interested.
    Any thoughts?
    Aug 2005
    Houston, TX
    Default Program
    I tried to attach it, but it didn't happen. I'll put it here.
    ' Capacitor Measurement
    ' Four digit common anode mulitplexed display
    ' Scan about 60/s (4ms pause)
    ' Driver 74HC4511
    ' Works for 2.0 uf (1K)- 100pf (20K)
    ' 8/20/06
    ' For 16F84A Chip
    ' Data output port A (Pin A5 NC)
    ' Pins 1 - 4 - Digit select for multiplex
    ' Pin5 - pot command
    ' Pin6 - Display Blanking signal (0 = blank)
    ' Pin7 - Range 1 = high value (1K resistor); 0 = low (20K)
    ' Digits 1 - 4; W1 - W4
    ' Measurement (Msr) W10
    Settings:
    Symbol Blank = pin6
    Symbol Range = pin7
    Symbol D1 = w1
    Symbol D2 = w2
    Symbol D3 = w3
    Symbol D4 = w4
    Symbol Msr = w10
    Symbol PortA = 5
    Poke $85, 0 ' Set port A to all outputs
    Output 1 ' Digit 1 - MSD
    Low 1 ' off
    Output 2 ' Digit 2
    Low 2
    Output 3 ' Digit 3
    Low 3
    Output 4 ' Digit 4
    Low 4
    Output 6 ' Blanking
    Low 6 ' Blank all segments
    Start:
    pause 750
    Blank = 0
    If range = 0 then testlow 'Check high or low state
    'Testhigh:
    pot 5,40,msr
    Msr = Msr*10 'Raise results for 4 digit display
    goto math
    Testlow:
    Pot 5,255, msr
    Msr = Msr*100
    Math: 'Set up digits in memory for display
    D1 = Msr/1000
    D4 = Msr//1000
    D2 = D4/100
    D4 = D4//100
    D3 = D4/10
    D4 = D4//10
    Display:
    poke porta, D1 'Send data
    High 1 'Select Digit
    Blank = 1 'Remove blanking
    Pause 4 'Pause
    Blank = 0 'Blank
    Low 1 'Unselect digit
    poke porta, D2
    High 2
    Blank = 1
    Pause 4
    Blank = 0
    Low 2
    poke porta, D3
    High 3
    Blank = 1
    Pause 4
    Blank = 0
    Low 3
    poke porta, D4
    High 4
    Blank = 1
    Pause 4
    Blank = 0
    Low 4
    Goto display
    AMay, I personally would tend to use a constant current source with the RCTIME function. That way you can measure the timing between 2 points with the cap charging at a fixed rate (much more linear). Remember that the resultant range can not be greater than 0 to 65535 so you will probably have to use different current levels to maintain accuracy over large ranges 100Pf to 100 uF. I have used this methode for measuring the backup storage of airbag modules capacitors in production equipment with great success. LOL
    Bear in mind that unlike Resistors, Capacitors are pretty much guaranteed NOT to be the value printed on them. With most Capacitors, if you're within 20% of what they're supposed to be, you've got a good one!
    So, if your gizmo is telling you it's 50% off... it could actually be telling you the truth!
    Aug 2005
    Houston, TX
    Default RCTIME function
    Thanks for the response.
    I can imagine a constant current source.
    I can imagine starting it, and stopping it with a comparator.
    I can't imagine how to time the interval in PIC basic. The books I have don't help, or I am not looking in the right place. (I am just a retired bookkeeper having fun with this.)
    I don't want to get involved with a separate counter. The author who got me started on this ran into all kinds of stability problems with his on the small caps.
    Wink Elektor !!!
    Some times ago, Elektor published a nice project about a capacitance meter; It's not PbP, but fairly works ...
    Project N° 020144 ... Programmed PIC and PCB available.
    Good choice ... if for measuring !!!
    T.Jackson's Avatar
    T.Jackson Guest
    Smile Modern Electrolytic Capacitors - Nothing To Fear!
    Many books quote it, I even recall one of my old tech teachers saying it: "Electrolytic capacitors have a huge varying degree of tolerance" But in practice, I have never measured any capacitor with a +/- 20% tol. I have however measured many of them faulty with very high ESR, which is a common fault with electrolytic capacitors used in switch mode circuitry. Sometimes, an extremely high ESR – near open circuit – will result in a somewhat lower capacitance measurement. All and all, I think modern-day components have traveled miles ahead. In reality, today, +/- 20% tol with anything would be very seldom.
    Trent Jackson
    Loveland CO USA
    Default Heathkit Capacitor substitution box
    I have old Capacitor substitution boxes dating back 50 years. (20 years for the Heathkit boxes) Large capacitors 2 to 470 uf do not last many years. I replaces all the large capacitors in my HeathKit radio 10 years ago. I have some capacitor boxes where one decade failed because of a bad switch. “Anything below 100 pf returns 0, even with a 10meg discharge resistor.“
    I think you should go to the store [DigiKey] and get some capacitors you know are good
