power Off/shutdown code/circuit
Results 1 to 8 of 8
    My initial routine is not reliable because I guess the following happens:
    1) turn on relay
    2) do the job
    3) turn off relay -> no AC power is applied
    4) the large 2000 uF capacity voltage goes down slowly, i.e below 4V
    5) the brown out logic kicks in -> resets the PIC which restarts from begining
    6) goto 1) --> AC power is applied again...
    will try the END statement as suggested above, otherwise will look at the LM2914 power regulator described in an other post.
    Eric
    Italy
    Describe the electrical circuit used to turn on the device.
    (Push button)?
    Best regards,
    Luciano
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  4. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  5. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
