Action on line sync
Results 1 to 3 of 3
    hansknec's Avatar
    hansknec Guest
    Default Action on line sync
    I have a project that needs to put out a series of pulses at zero crossing of the 60hz line. I have a zero crossing detector that outputs a 350us pulse at the line rate. I have played around with the interrupts and assembly instructions to get my output pulses close (1.2usec) to the trigger, but of course you can never instantly perform an action. I think I probably violated some PIC law by not saving my pointers in the interrupt routine, but it works. Here is the working code:
    ' acctune.pbp     Proven to work 8-21-06
    ' Interrupt on rising edge of beam sync using PIC16F84A-20
    ' Interrupts in assembly language, mixing basic between assembly
    ' calls.  This method drasticaly improves capturing the edge of an external
    ' signal. Edge is captured, the interrupt is called, then some basic commands
    ' are performed to create the pulse structure.    Total time delay
    ' from beam sync rising edge to PIC pulse generation is 1.2usec. Beam sync is a
    ' 350usec long ttl pulse that occurs at a 60hz rate.
    ' Interrupt on PORTB.0 (INTE) will create a tune mode pulse on PORTB.1
    Define 	OSC		20
    out     var     PORTB.1  ' alias for the output pin.
    define  INTHAND myint   ' Define interrupt handler
    Goto start              ' Skip around interrupt handler, but always put the
                            ' handler in the front of the program.
    asm    ; Assembly language interrupt handler
    myint
    ;normally one would save all the pointers here, but I'm interested in getting
    ;my pulses out ASAP.  It works without a save and restore of pointers. I
    ;guess because my code isn't changing anything important.
    endasm
    out = 1   'Take the pin high
    PAUSEUS 200
    out = 0   'Take pin low
    PAUSEUS 100
    out = 1
    PAUSEUS 4        'results in exactly 4.2usec at 20Mhz clock.
    out = 0
    pauseus 100  'guarantees that we won't trigger on other edge of beam sync.
                 'we were triggering on a rising edge, but if noise occurs during
                 'falling edge it might cause a false trigger.
    asm
            bcf     INTCON, 1       ; Clear interrupt flag
    endasm
    @        retfie                  ; Return from interrupt
    start:  TRISB = %11111101          ' I/O 1 is output, all others are in
            OPTION_REG = %01111111     ' Enable PORTB pullups, interrupt on
                                       ' rising edge of RB0.
            INTCON = %10010000      ' Enable INTE interrupt
    loop: goto loop   ' get stuck here to prove true interrupt capability
    Now I should be satisfied with the 1.2usec delay but I'm not. I want my pulse train to output within 200nsec of line crossing. Since 60hz line crossing is a highly repetitive signal it would seem to be a simple matter to have the sync signal reset a timer and then output my pulse when the timer is at a value corresponding to 16.6666ms. So far this idea is stuck in my head and I'm not sure if it would work because the next real line crossing would reset the timer and it might not actually reach the count. So I guess I would have to toggle between two counters that get reset every other cycle. Then there's the problem of phase errors when 60hz becomes 59.9 or 60.1 hz.
    Any ideas out there?
    I know I can do this with straight digital logic chips, but they aren't as fun as pics. I can also use an 18F PIC with the HSPLL to get 40MHz, which would bring my pulses within 600ns with my existing code.
    Are there any assembly Guru's out there that can tell me why I luck out not saving and restoring my pointers?
    I'm no ASM expert but here's some thoughts:
    First on the timings you get.
    Each PIC instruction takes 1-2 cycles, GOTO takes 2. When the interrupt occurs the program first jumps to the interruptvector (0004h) which in turn points to the adress of your interrupt handler and the software then jumps there. So that's 2 GOTO's for a total of 4 cycles or 800nS @ 20MHz. Then comes your out=1 statement which takes another 200nS for a total of 1uS the remaining 200nS delay may be the difference between RB0 going high and the interrupt request being latched in the PIC by the clock.
    So a think that 1-1.2uS is probably the best you can do with this aproach.
    Second,
    I agree, logic chips aren't as fun as PIC's but if you can live with just one logic chip you could use a RS-latch and set it with the rising edge of your zero crossing pulse and at the same time start a timer in the PIC which will reset the latch after 200uS.
    If that works perhaps you could perhaps tie a second PIC-pin to the latch output (isolated from each other with diodes) and use the timer or your PauseUs sequence to pulse it. I beleive that would get your latency down a bit further.
    On the context saving I think it's probably like you say. Your main program does nothing that uses any of the registers that usually needs to be saved so that's why it works. Just don't try to do any 'real' work in the main program....
    HTH
    /Henrik Olsson.
    hansknec's Avatar
    hansknec Guest
    Excellent suggestion for the RS latch. This is much easier than any of my other ideas.
    John
  1. Darrel Taylor - Instant Interrupts-Problem 16F877A
    Last Post: - 31st December 2009, 14:19
  2. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  3. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  4. Loop with two motor and 2 sensors
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
