power Off/shutdown code/circuit
Results 1 to 8 of 8
    Default power Off/shutdown code/circuit
    I'd like to completely power off a PIC based circuit after the job is done. Currently I've a relay that controls AC power to the circuit, the relay is driven by PORTA.0. the logic is somewhat like this
    PORTA.0=1 ' relay is ON, power is applied to PIC
    ....do the job
    PORTA.0=0 ' relay is OFF
    FOR I=1 to 1000 'start a loop to die until DC power is disappears
    Pause 1000
    NEXT I
    unfortunately this is not reliable
    Any hint ? using an external transistor connected to MCLR ?
    Jun 2005
    Wisconsin
    In what way is it not reliable?
    BTW you could replace:
    Pause 1000
    NEXT I
    With:
    More detail and a schematic will help. PIC# too
    Jun 2006
    "PORTA.0=1 ' relay is ON", Isn't PORTA.0=0 ' relay is ON?
    Italy
    Try to disable the Brown-out reset circuit.
    Best regards,
    Luciano
    My initial routine is not reliable because I guess the following happens:
    1) turn on relay
    2) do the job
    3) turn off relay -> no AC power is applied
    4) the large 2000 uF capacity voltage goes down slowly, i.e below 4V
    5) the brown out logic kicks in -> resets the PIC which restarts from begining
    6) goto 1) --> AC power is applied again...
    will try the END statement as suggested above, otherwise will look at the LM2914 power regulator described in an other post.
    Eric
    Italy
    Describe the electrical circuit used to turn on the device.
    (Push button)?
    Best regards,
    Luciano
    Default Power off
    Hello,
    I have a low cost idea, install an SCR between the voltage regulator and the load (PIC) make sure the filter capacitor is on the load side of the scr. Using your existing relay setup the SCR will disengage when power is cut off to the SCR and will not reapply power if power supply should power up again,bias the gate so it requires a significant voltage to trigger it to prevent Ghost startups, otherwise a simple latching relay setup like power tools use would do as well.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  4. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  5. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
