Serin with low voltage
Results 1 to 4 of 4
Threaded View
  1. #4
    Quote Originally Posted by mister_e
    http://www.picbasic.co.uk/forum/show...57&postcount=6
    Also, you have a free USART in your PIC, you should use it. HSEROUT, HSERIN instead. But you have to use the dedicated pins PORTB.2 and PORTB.5
    lol
    I really do have code blindness.........
    I owe you a great thankyou, or apology for disbelief, but even though I had included lines to switch off the analog stuff I had one with a little mistake in it, and I had looked at it at least a 100 times as I scrolled down to where I thought the fault was................
    The 'thing' now works a treat, and I have real data going back in on porta, now to shift it to port b......
    (edit)
    I have moved the code to port b, and it now works, which explains nothing, as even with analog enabled on port A, port B should work just the same! agh!
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  2. Microcontroller with 2 way paging application problem
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 19:29
