Wiegand data and com port
Results 1 to 40 of 54
Threaded View
  1. #13
    Tallinn, Estonia
    Hi!
    Serial string "ID xxxxxx" is output on GPIO0 if GPIO1 is at high level (enable pin). Taking GPIO1 low will disable output. Output speed is 4800 bd.
    If you mix up D0 and D1, data will still be output but card number will be wrong.
    I have the same code working at 16F628 too. It really requires only minimal changes.
    I will "release" a newer version on reader code now (should be attached). Late program had problems with certain types of readers: it did not read anything. Present code fixes it. One more bug is fixed.
    About OSCCAL (calibration data). My serial output (bit-banging) routine (actually not mine, I guess mr. Myke Predko wrote it) relies on chips internal oscillator. It's frequency must be exactly 4MHz or receiving computer will fail to read stream. Microchip has made PIC's internal osc's frequency adjustable by means of changing one conf byte - the OSCCAL. It has been set in factory to some (correct) value. When you burn chip, it will get a new value from the .HEX file. This must be avoided. I am not sure about PonyProg but most PIC programmers now about that trick and ask user for the right value. Programmer can read it from chip and then, after burning code, restore it.
    Happy PICing!
    /Felch
