Crystal vs Resonator
Results 1 to 6 of 6
    Jun 2005
    Wisconsin
    Default Crystal vs Resonator
    I'm constructing a circuit for outdoor use. I was thinking about using a resonator to save space vs. a crystal/capacitor combo.
    Any advantages or disadvantages I need to consider?
    Hi Dynamo,
    If there are no critical time issues ... no problem. just have a look at tempco and freq. precision to see what.
    Jun 2005
    Wisconsin
    I'm doing serial @9600, I2C, and OWIN/OWOUT.
    A resonator is good for the above and should save you a couple of capacitors if you select one with internal caps.
    Jun 2005
    Wisconsin
    I had two thoughts while laying out the board, save on space AND I believe a resonator is better when there are going to be temperature extremes. Correct?
    Oct 2006
    WEST VIRGINIA, USA
    Crystals Are Better For Initial Calibration Accuracy And Temperature Stability.
    Resonators Are Typically 0.3% Accurate And 0.1% Temperature Stability, While Crystals Are 0.005% On Both Accounts. In Most Applications, The Resonator Is Adequate However.
    I Have One Project That Has Timers Running Up To 24 Hour Range And Temperature Exposure Of 0-90 Degrees Farenheit And Used A Crystal For Stability.
    Most Projects I Design Are Ok With The Internal Rc Clock.
  1. Sharing Crystal with 2 IC's
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 10th January 2013, 13:33
  2. Resonator Suppliers for 40 MHz?
    By mcphill in forum General
    Last Post: - 23rd January 2009, 02:05
  3. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 05:06
  4. Crystal osc running but PIC not using it
    By p15218 in forum mel PIC BASIC Pro
    Last Post: - 18th February 2007, 22:33
  5. Replies: 1
    Last Post: - 30th June 2004, 08:07
