Making RA6 (OSC2) an output on a 18F2525
Results 1 to 4 of 4
Threaded View
  1. #2
    you'll have no other choice than alter config fuses using methods stated in the following thread...
    OR set them manually before programming your PIC.
    Also, read the OSCCON section. page 30 table 2-2 to change the 1MHZ default speed in case you want to use the internal OSC instead.
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 02:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 19:50
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
