Jumper,
Did you erase "block 0" first?
Also the 4620 needs to write 64 bytes at a time, instead of 32.
Jumper,
I forgot to erase the code first.
It is allowed to write either 64 BYTES or 32 WORDS, I went for writig words
/me
When using ERASECODE don't forget this (a part from an e-mail from Melab support)
The erase blocks of 64 bytes do, in fact, have specific start/end
addresses that are arranged starting at address 0. The datasheet
refers to these blocks as "rows".
Each block (0-63, 64-127, etc.) will be erased in its entirety when
you use ERASECODE at any address within the block.
If you want to preserve part of the data in a block, use READCODE to
save the information before you erase, then WRITECODE to restore the
block with modified data afterward.
The best way is to learn from other's misstakes :-)
/me
