IR detector
Results 1 to 29 of 29
Thread: IR detector
    WOOT Thanks again Bob I dropped the voltage down to like 4.5V using 3AA batteries instead of a 9V, reduced the resistor on the LED and connected like you said... It works perfect! thanks I would like to know if there is a way with resistors to do the same thing and use a 9v if possible.
    malc-c's Avatar
    malc-c Guest
    You could use a 5.1v zenner diode to reduce the 9v down to 5v, but a small 5v regulator should be a better bet.
    I guess this is where I get confused with electronics.
    I can take a 9V battery and use a resistor to run a 1.5V led without problem but I can't use a resistor the same way to run a 5V chip.
    This seems to make sense to everyone but me lol
    Ok on to the coding would this chip be able to handle the timer part of this or would I need a dedicated timer chip?
    My guess is that there will be about 100 breaks in the beam in a 30 second time.
    Currently I'm testing with this code and a led on RB1.
    if PORTB.0 = 1 then
    high PORTB.1
    low PORTB.1
    Now that looks like it will work fine but, if the loop happens more than once before the bean is brought back it could count 10 times for every break...
    Would this code work and only count once?
    broken var byte
    broken = 0
    if PORTB.0 = 1 and broken = 0 then
    broken = 1
    high PORTB.1
    low PORTB.1
    if PORTB.0 = 0 and broken = 1 then broken = 0
    goto Main
    Hi geckogrotto. Try something like this.
    START:
    LET BROKEN = 0
    LOW PORTB.1
    IF PORTB.0 = 1 then ACTIVATE 'BEAM BROKEN
    GOTO MAIN 'BEAM NOT BROKEN
    ACTIVATE:
    IF PORTB.0 = 1 THEN ACTIVATE 'WAIT FOR BEAM TO RETURN
    LET BROKEN = BROKEN + 1
    IF BROKEN >= 10 THEN LIGHTUP 'BEAM NEEDS TO BE BROKEN 10 TIMES
    GOTO MAIN
    LIGHTUP:
    HIGH PORTB.1
    GOTO LIGHTUP
    Thanks for your suggestion.
    Can anyone tell me how to turn on a timer then turn it off and get the amount of time that was timed?
    Default Voltage divider
    Hi, yes you can reduce the voltage to any set level you choose.
    Using Ohm's Law
    V. out = V in X (r2 / r1 + r2)
    where r1 is the resistor closest to the power in
    and r2 is the resistor closest to ground
    Example v out = v in or 10 volts X r2, say 500 ohms . . . 5000
    divided by r2 + r1, so if r1= 500 ohms you would get 1000 ohms,
    so 5000 / 1000 = 5 volts. Simple huh? The problem here is if you lose the ground
    foe even an instant then your input sees full supply voltage, also a voltage divider uses power all the time, in this example .01 amp.
    OK the attachment didn't work so basicly two resistors in series, one end attached to + and the otherend to minus and you pull power from the connection in the center.
    Last edited by Archangel; - 16th August 2006 at 20:21. Reason: TRy to add BMP of schematic
    Quote Originally Posted by Joe S.
    Using Ohm's Law
    Ok I don't think these actually exist but lets say they do.
    If I had exactly 9V in and used
    R2 950
    R1 760
    That would give me exactly 5V out?
    About the connection what your saying is resistor to + and the other resistor connected to that and then to the negative and sandwiched in between the 2 would be my output of 5v?
    Also if you want shoot me over the attachment to [email protected]
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 11:40
  3. Replies: 10
    Last Post: - 16th October 2006, 18:23
  4. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 17:12
  5. IR for robot on 16F877A
    By Samuel in forum mel PIC BASIC Pro
    Last Post: - 9th April 2005, 20:57
