Automotive Use
Results 1 to 12 of 12
Thread: Automotive Use
    Default Automotive Use
    Does anybody have a really elegant way to switch PIC inputs from12 to 24 volt sources, I'm thinking automotive, marine, or even aircraft sources, I was thinking voltage divider, but . . . is there a better way?
    Exclamation Doe!
    I had to quote Homer Simpson on this one - Stupid question!
    I guess that is what opto isolators and current limiting resistors are for , stupid me!
    J. S.
    Jun 2005
    Up the bush, Western Plains, NSW Au
    One thing I have seen used, but not used myself, is to use 78L05 regulators with the input to the high voltage you want to detect, and the 5v output going to the PIC input pin.
    Seems pretty good in theory, as any variations in the input will just be absorbed by the regulator. A bit better than voltage divider etc???
    Default Creative!
    In 1,000 years I do not belive I would have tried that! It sounds like a terrific
    Idea, cheap, easy to implement, small footprint, I don't think it would be great on a real low power application but most automotive apps. are not low power!
    I'm going to try it! THANKS ! ! !
    I love it when creative people get together and swap Ideas!
    Joe Stokes
    Lightbulb
    Hi, Joe
    A simple opto-coupler ( 4 pins footprint for the TLP 620 i.e. ) ... will do it really nice.
    And avoid ground interconnections too !!!
    Default It Works Really Well
    muddy0409
    Your idea to use LM7805 integrated circuit regulators is a GEM, it works well and it takes up way less room on the circuit board than an opto coupler, opto isolator and requires no resistor for the led as in the opto device, thereby making PC board layout a snap. Very innovative, Thanks Again! JS
  1. Persistence of Vision on Automotive wheel
    By Wax-um in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 16:06
  2. Automotive (or super bright) LEDs
    Last Post: - 11th April 2007, 16:55
  3. DS1307 automotive application
    By DynamoBen in forum Schematics
    Last Post: - 31st August 2006, 01:33
  4. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 16:46
