R2R resistor networks
Results 1 to 9 of 9
    Aug 2004
    Default r2r
    Hi:
    I did check Mouser and Bourns and they do not have any.
    The Bourns number I had was 4116R-R2R-103.
    Thanks anyway...
    Greetings...
    Ruben de la Pena
    Default Confused
    I Googled your part number and it returned 4 pages of links, these three appear to sell the part number you specified. Is there some reason a substitute will not work? These SIPS are generally pretty generic, either common to one pin or all seperate. Mouser does indeed sell resistor networks as do many others.
    http://www.hkinventory.com/public/Of...t4=0&datecode=
    http://www.partminer.com/pagedetail/5300/11
    http://www.accordtech.com/comp18_19.php
    Default more . . .
    http://www.bourns.com/PDFs/r2r.pdf
    the 4116r-r2r-103 seems to be a discontinued unit here is a link to the datasheet for comparison to substitutes.
    JS
    Aug 2004
    Default more...
    Hi:
    I did search in Goggle and even put quoting requests in several, and I got emais with "out of stock" response.
    The families found at Bourns, are resistor and terminatos, but not R2R.
    I am really intrigued ... Nobody uses R2R...?
    Thanks...
    Ruben de la Pena V
    Aug 2004
    Default At last...
    Hi:
    I finally receive a quotation from Electrospec Inc.
    They have a soic version BIT 628L103.
    Thanks to all for your help...
    Greetings
    Ruben de la Pena
