Hi:
I did check Mouser and Bourns and they do not have any.
The Bourns number I had was 4116R-R2R-103.
Thanks anyway...
Greetings...
Ruben de la Pena
I Googled your part number and it returned 4 pages of links, these three appear to sell the part number you specified. Is there some reason a substitute will not work? These SIPS are generally pretty generic, either common to one pin or all seperate. Mouser does indeed sell resistor networks as do many others.
http://www.hkinventory.com/public/Of...t4=0&datecode=
http://www.partminer.com/pagedetail/5300/11
http://www.accordtech.com/comp18_19.php
http://www.bourns.com/PDFs/r2r.pdf
the 4116r-r2r-103 seems to be a discontinued unit here is a link to the datasheet for comparison to substitutes.
JS
Hi:
I did search in Goggle and even put quoting requests in several, and I got emais with "out of stock" response.
The families found at Bourns, are resistor and terminatos, but not R2R.
I am really intrigued ... Nobody uses R2R...?
Thanks...
Ruben de la Pena V
Hi:
I finally receive a quotation from Electrospec Inc.
They have a soic version BIT 628L103.
Thanks to all for your help...
Greetings
Ruben de la Pena
