Sensor temperature MCP9800-1-2-3
Results 1 to 7 of 7
    Sep 2006
    Not bad, I tried this one and it worked, had problems with the LCD grounding but the code was good, this code is also suitable for many other temp sensors.
    Jul 2004
    It's possible to pull the i2c bus and put the mcp9803 temp sensor far away from controller ?(Around 2 meters by using shielded cable)
    Thanks.
    Mar 2008
    Switzerland
    Hello *
    I connect MCP9801 to the PIC and i put the 3 Adressline to VCC (A0,A1,A2)
    So i change onliy the 2 Lines of the Programm above:
    adr_R con %10011111 ;adr mpc9803 read Adresse 111
    adr_W CON %10011110 ;adr mpc9803 write Adresse 111
    I get always 16.0 C on the display.
    Thank for feedback.
    Rolf
    Quote Originally Posted by Omalik View Post
    The sensor is 16C?
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  4. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
