Sensor temperature MCP9800-1-2-3
Results 1 to 7 of 7
    steneor's Avatar
    steneor Guest
    Hi!
    This is my first solution.
    '* Name : MCP9803.BAS *
    '* Author : Ernesto *
    '* Notice : test MCP9803 with pic18f2680 *
    '* Date : 30/07/2006 *
    '* Version : 1.0 *
    '* Notes : *
    define LOADER_USED 1 ' utilisation du Bootloader Tinybld 1.91
    define OSC 40 ' Quartz ŕ 10MHz * 4
    DEFINE HSER_BAUD 19200 ' set baud rate to 19200
    FLOAT VAR WORD '
    SDA var PORTC.4
    SCL var PORTC.3
    T_MSB var byte 'Température MSB Signe + 7 Bit
    T_LSB var byte 'Temperature lsb decimal
    ;MCP9800 DATASHEET
    adr_R con %10010001 ;adr mpc9803 read
    adr_W CON %10010000 ;adr mpc9803 write
    MCP9800_TEMPERATURE CON 0 ; Register pointer
    MCP9800_CONFIGURATION CON 1
    MCP9800_HYSTERESIS CON 2
    MCP9800_LIMITSET CON 3
    ONESHOT_OFF CON %00000000 ;bit for register configuration
    ONESHOT_ON CON %10000000
    RESOLUTION_9bit CON %00000000
    RESOLUTION_10bit CON %00100000
    RESOLUTION_11bit CON %01000000
    RESOLUTION_12bit CON %01100000
    FAULT_QUEUE_0 CON %00000000
    FAULT_QUEUE_2 CON %00001000
    FAULT_QUEUE_4 CON %00010000
    FAULT_QUEUE_6 CON %00011000
    ALERT_ACTIVE_LOW CON %00000000
    ALERT_ACTIVE_HIGH CON %00000100
    COMP_MODE CON %00000000
    INT_MODE CON %00000010
    SHUTDOWN_OFF CON %00000000
    SHUTDOWN_ON CON %00000001
    MCP9800_CONFIG con oneshot_off | Resolution_11bit |Fault_queue_0 | ALERT_active_low | Comp_mode | shutdown_off
    debut:
    hserout [$D,$A]
    hserout ["************************************************* ",$D,$A]
    hserout ["* Test du capteur de température MCP9803 *",$D,$A]
    hserout [$D,$A]
    init_MCP9800:
    i2cwrite SDA,SCL,adr_W,[mcp9800_configuration,mcp9800_config]
    i2cwrite SDA,SCL,adr_W,[mcp9800_temperature]
    loop:
    i2cread SDA,SCL,adr_R,[T_msb,T_lsb]
    ;float = (T_lsb >>7 ) * 5 ; resolution 9 bit
    ;float = (T_lsb >>6 ) * 25 ; resolution 10 bit
    float = (T_lsb >>5 ) * 125 ; resolution 11 bit
    hserout ["T_msb=",BIN8 T_msb," T_lsb=",BIN8 T_lsb, " Température =",SDEC T_msb,",",dec float,"C" ,$D,$A]
    pause 200
    goto loop
    Sep 2006
    Not bad, I tried this one and it worked, had problems with the LCD grounding but the code was good, this code is also suitable for many other temp sensors.
    Jul 2004
    It's possible to pull the i2c bus and put the mcp9803 temp sensor far away from controller ?(Around 2 meters by using shielded cable)
    Thanks.
    Mar 2008
    Switzerland
    Hello *
    I connect MCP9801 to the PIC and i put the 3 Adressline to VCC (A0,A1,A2)
    So i change onliy the 2 Lines of the Programm above:
    adr_R con %10011111 ;adr mpc9803 read Adresse 111
    adr_W CON %10011110 ;adr mpc9803 write Adresse 111
    I get always 16.0 C on the display.
    Thank for feedback.
    Rolf
    Quote Originally Posted by Omalik View Post
    The sensor is 16C?
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  4. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
