pulse simulation
Results 1 to 13 of 13
    May 2006
    Default pulse simulation
    to simplify :no button
    ' pic16F877
    'cycle = !-!_!-!_!-!_!-!_!-!__!--!_
    ' i use lcd just to see W0
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 8
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    INCLUDE "modedefs.bas" ' Include serial modes
    W0 var word
    W1 var word
    i var byte
    up var PORTB.4
    dn var PORTB.5
    rst var portb.6
    b0 var byte
    PO var portb.3 ' Define pulse output pin
    'initialisation
    ADCON1 = %0000111
    TRISA = %1
    w0=1000
    i=0
    B0=0
    Low PO ' Initialize output polarity
    pulse:
    for i =0 to 5
    Pulsout 3,W0 ' Generate pulse
    pause W0/100 ' Intra-pulse delay
    next i
    I=0
    Pulsout 3,W0
    W1=W0*2
    Pause W1/100
    Pulsout 3,W1 'double pulse ok
    pause W0/100
    'visualisation sur LCD
    Lcdout $FE,$C0,"W0 = ",dec W0," "
    Goto PULSE 'repeat cycle
    I want a double pulse in end cycle but before new cycle , i want simple pediod low but it not equal w0!!!
    May 2006
    I remove lcd and it s ok
    May 2006
    now, the interruption does not work.
    they are detected but not the button pressed and w0 pass to 0
    ' pic16F877
    W0 var word
    W1 var word
    i var byte
    up var PORTB.4
    dn var PORTB.5
    rst var portb.6
    b0 var byte
    OPTION_REG = $7f
    'initialisation
    ADCON1 = %0000111
    TRISA = %1
    w0=100
    i=0
    B0=0
    INTCON.0 = 0 'Clear Port Change Interrupt Flag bit
    On interrupt goto bouton ' Define interrupt handler
    INTCON =%10001000 'Enable RBIE
    pulse:
    for i =0 to 5
    next i
    Pulsout 3,W0
    W1=W0*2
    Pause W1/100
    Pulsout 3,W1
    pause W0/100
    Goto pulse
    inc:
    'Lcdout $FE,$C0,"INC"
    W0 = W0 + 1
    W1=W0
    resume
    goto pulse
    decr:
    W0 = W0 - 1
    W1=W0
    goto pulse
    reset:
    w0 = 100
    W1=W0
    goto pulse
    DISABLE
    bouton :
    INTCON.0 = 0 '
    if PORTB.4=0 THEN goto inc 'not detect
    if PORTB.5=0 THEN goto decr 'not detect
    if PORTB.6=0 THEN goto reset 'not detect
    GOTO PULSE
    ENABLE
    Lightbulb
    do not mix resume and goto's ...
    a clear algorithm could help you.
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  4. Replies: 3
    Last Post: - 13th September 2008, 17:40
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 10:39
