sorry bur i dont understand how use interrupt on a port.
i m bad
i m bad
I work but it is hard
this code work
' pic16F877
'cycle = !-!_!-!_!-!_!-!_!-!__!--!_
' i use lcd just to see W0
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 8
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
DEFINE OSC 4 ' use 20 MHZ oscillator
INCLUDE "modedefs.bas" ' Include serial modes
W0 var word
W1 var word
i var byte
up var PORTB.4
dn var PORTB.5
rst var portb.6
b0 var byte
PO var portb.3 ' Define pulse output pin
'initialisation
ADCON1 = %0000111
TRISA = %1
w0=100
i=0
B0=0
Low PO ' Initialize output polarity
intcon=%0001000
On Interrupt Goto bouton ' Define interrupt handler
INTCON = $90 ' Enable INTE interrupt
pulse:
for i =1 to 5
Pulsout 3,W0 ' Generate pulse
pause W0/100 ' Intra-pulse delay
next i
Pulsout 3,W0
W1=W0*2
Pause W1/100
Pulsout 3,W1
'visualisation sur LCD
Lcdout $FE,$C0,"W0 = ",dec W0," "
Goto bouton
inc:
W0 = W0 + 10
goto pulse
decr:
W0 = W0 - 10
goto pulse
reset:
w0 = 100
goto pulse
bouton :
disable
button up,1,0,0,b0,1,inc 'si bouton1 sur port1=1 aller à calibration
button dn,1,0,0,b0,1,decr 'si bouton1 sur port1=1 aller à calibration
button rst,1,0,0,b0,1,reset 'si bouton1 sur port1=1 aller à calibration
enable
goto pulse
but why on the piture the period after double pulse the low period its not equal w0?
PAUSE Missing after PULSOUT 3, W1
Goto Pulse instead of Goto Bouton ---- mais à quoi servent donc les interruptions ???
et on termine en plaçant la visualisation dans le programme d'interruption juste AVANT le Enable !!! ( ça évite les affichages Ollé, Ollé ...)
to simplify :no button
' pic16F877
DEFINE LCD_DBIT 8
DEFINE LCD_RSBIT 0
DEFINE LCD_EBIT 1
W0 var word
W1 var word
i var byte
up var PORTB.4
dn var PORTB.5
rst var portb.6
b0 var byte
'initialisation
ADCON1 = %0000111
TRISA = %1
w0=1000
i=0
B0=0
pulse:
for i =0 to 5
next i
I=0
Pulsout 3,W0
W1=W0*2
Pause W1/100
Pulsout 3,W1 'double pulse ok
pause W0/100
Goto PULSE 'repeat cycle
I want a double pulse in end cycle but before new cycle , i want simple pediod low but it not equal w0!!!
now, the interruption does not work.
they are detected but not the button pressed and w0 pass to 0
' pic16F877
W0 var word
W1 var word
i var byte
up var PORTB.4
dn var PORTB.5
rst var portb.6
b0 var byte
OPTION_REG = $7f
'initialisation
ADCON1 = %0000111
TRISA = %1
w0=100
i=0
B0=0
INTCON.0 = 0 'Clear Port Change Interrupt Flag bit
On interrupt goto bouton ' Define interrupt handler
INTCON =%10001000 'Enable RBIE
pulse:
for i =0 to 5
next i
Pulsout 3,W0
W1=W0*2
Pause W1/100
Pulsout 3,W1
pause W0/100
Goto pulse
inc:
'Lcdout $FE,$C0,"INC"
W0 = W0 + 1
W1=W0
resume
goto pulse
decr:
W0 = W0 - 1
W1=W0
goto pulse
reset:
w0 = 100
W1=W0
goto pulse
DISABLE
bouton :
INTCON.0 = 0 '
if PORTB.4=0 THEN goto inc 'not detect
if PORTB.5=0 THEN goto decr 'not detect
if PORTB.6=0 THEN goto reset 'not detect
GOTO PULSE
ENABLE
