pulse simulation
Results 1 to 13 of 13
    May 2006
    Default pulse simulation
    if i use
    GOTO_INC
    it 's ok?
    Default Noooooooooo....
    and how to place it in location 4 ????
    D.E.F.I.N.E. !!!!!
    May 2006
    Unhappy pulse simulation
    sorry bur i dont understand how use interrupt on a port.
    i m bad
    May 2006
    I work but it is hard
    this code work
    ' pic16F877
    'cycle = !-!_!-!_!-!_!-!_!-!__!--!_
    ' i use lcd just to see W0
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 8
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE OSC 4 ' use 20 MHZ oscillator
    INCLUDE "modedefs.bas" ' Include serial modes
    W0 var word
    W1 var word
    i var byte
    up var PORTB.4
    dn var PORTB.5
    rst var portb.6
    b0 var byte
    PO var portb.3 ' Define pulse output pin
    'initialisation
    ADCON1 = %0000111
    TRISA = %1
    w0=100
    i=0
    B0=0
    Low PO ' Initialize output polarity
    intcon=%0001000
    On Interrupt Goto bouton ' Define interrupt handler
    INTCON = $90 ' Enable INTE interrupt
    pulse:
    for i =1 to 5
    Pulsout 3,W0 ' Generate pulse
    pause W0/100 ' Intra-pulse delay
    next i
    Pulsout 3,W0
    W1=W0*2
    Pause W1/100
    Pulsout 3,W1
    'visualisation sur LCD
    Lcdout $FE,$C0,"W0 = ",dec W0," "
    Goto bouton
    inc:
    W0 = W0 + 10
    goto pulse
    decr:
    W0 = W0 - 10
    goto pulse
    reset:
    w0 = 100
    goto pulse
    bouton :
    disable
    button up,1,0,0,b0,1,inc 'si bouton1 sur port1=1 aller à calibration
    button dn,1,0,0,b0,1,decr 'si bouton1 sur port1=1 aller à calibration
    button rst,1,0,0,b0,1,reset 'si bouton1 sur port1=1 aller à calibration
    enable
    goto pulse
    but why on the piture the period after double pulse the low period its not equal w0?
    May 2006
    help please
    Wink Nothing strange.
    PAUSE Missing after PULSOUT 3, W1
    Goto Pulse instead of Goto Bouton ---- mais à quoi servent donc les interruptions ???
    et on termine en plaçant la visualisation dans le programme d'interruption juste AVANT le Enable !!! ( ça évite les affichages Ollé, Ollé ...)
    May 2006
    to simplify :no button
    ' pic16F877
    DEFINE LCD_DBIT 8
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    W0 var word
    W1 var word
    i var byte
    up var PORTB.4
    dn var PORTB.5
    rst var portb.6
    b0 var byte
    'initialisation
    ADCON1 = %0000111
    TRISA = %1
    w0=1000
    i=0
    B0=0
    pulse:
    for i =0 to 5
    next i
    I=0
    Pulsout 3,W0
    W1=W0*2
    Pause W1/100
    Pulsout 3,W1 'double pulse ok
    pause W0/100
    Goto PULSE 'repeat cycle
    I want a double pulse in end cycle but before new cycle , i want simple pediod low but it not equal w0!!!
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  4. Replies: 3
    Last Post: - 13th September 2008, 17:40
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 10:39
