pulse simulation
Results 1 to 13 of 13
    May 2006
    Default pulse simulation
    hello
    i want simulate a cycle rpm sensor for automotive.
    http://www.geea.org/IMG/swf/capteur_vitesse_6.swf
    the frequency must be able.
    i ve test this code (!!! it s not the same cycle of the picture)
    ' _!-!_!-!__!--!_!-!_!-!
    ' pic16F877
    ' Variable
    W0 var word
    W1 var word
    i var byte
    up var PORTB.4
    dn var PORTB.5
    w0=0
    i=0
    'DN Define frequency down button
    'UP Define frequency up button
    PO con 3 ' Define pulse output pin
    low PO ' Initialize output polarity
    inc:
    If (up = 1) Or (W0 = 10000) Then decr ' Increment freq on button
    W0 = W0 + 10
    decr:
    If (dn = 1) Or (W0 = 0)Then pulse ' Decrement freq on button
    W0 = W0 - 10
    pulse:
    for i =1 to 38
    Pulsout 3,W0 ' Generate pulse
    Pause W0/100 ' Intra-pulse delay
    next i
    Pulsout 3,W0
    W1=W0*2
    Pause W1/100
    Pulsout 3,W1
    Goto inc ' Forever
    this code is ok but not optimized with button
    how do? use pulsout or pwm?
    thank
    Lightbulb Darrel instant interrupts ... of course !!!
    Hi, Nicolas
    Use DT interrupts !!! ... it's not so difficult to use.
    http://www.picbasic.co.uk/forum/showthread.php?t=3251
    or a little trick I discovered :
    insert " DEFINE INTHAND _INC" at the top of the program ... This places a "GOTO _INC" at location 00004 of the ASM program.
    Now trim the interrupt register ( INTCON) to allow an " interrupt on PortB Change "
    Place a correct preset value for W0 ... 0 is not a good value !!! ( in "decr:" nor !!! )
    Place a "GOTO PULSE " before "inc"
    Think to re-enable interrupts, placing " INTCON.7 = 1" just past "pulse" label
    last, change "GOTO inc" to "GOTO pulse"
    That should go at first...
    Next step will be to use BUTTON instead of IF-THEN ... just to use the Auto-repeat feature ...
    One more step ...
    Have a look to Motorola ( yessss ... Freescale !!! ) "TPUPN xx" Application Notes ...
    really Great !!!
    http://www.bgsoflex.com/megasquirt.html
    May 2006
    how place a "GOTO _INC" in microcode studio.
    interrupt register ( INTCON) to allow an " interrupt on PortB : INTCON=00001000 , it s ok?
    thank
    May 2006
    if i use
    GOTO_INC
    it 's ok?
    Default Noooooooooo....
    and how to place it in location 4 ????
    D.E.F.I.N.E. !!!!!
    May 2006
    Unhappy pulse simulation
    sorry bur i dont understand how use interrupt on a port.
    i m bad
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  4. Replies: 3
    Last Post: - 13th September 2008, 17:40
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 10:39
