sms to control pic..pls help...
Results 1 to 40 of 54
Threaded View
  1. #6
    Quote Originally Posted by Ziki
    thx for the info ... i believe t610 can support text mode ? izzit true ?
    No the t100, t68, t681, t610 I can say with definate authority only support PDU mode.
    This makes them a total pain for sms controllers.
    You have to type the sms command very carefully......
    If you sent alarm arm it would be 09417658DE0685E56D
    if you sent alarm arm. it would be 0A417658DE0685E56D17
    If you sent alarm arm it would be 09A0203B2C6F83DE6E
    Just one extra space makes it totally different.....
    You have to be very strict on how messages have to be sent, which also means you can just check parts of the string like this as most of it will always be the same.
    Alarm arm 0AD09417658DE0685E56D
    Alarm off 0AD09417658DE06BDCD66
    You can just test at various points to parse it IE
    0AD09 (4176) 58DE06B (DCD) 66
    0AD09 (4176) 58DE068 (5E5) 6D
    Put it all in a byte array and then 'if then it'
    If buf(6)<>"4" then wait_for_command
    if buf(6)<>"1" then wait_for_command
    If buf(6)<>"7" then wait_for_command
    If buf(6)<>"6" then wait_for_command
    ' Ok so we have a command, now which one
    If buf(17)<>"D" then not_arm_command
    If buf(18)<>"C" then not_arm_command
    If buf(19)<>"D" then not_arm_command
    ' OK we got here so its 'arm' command
    Gosub arm_the_alarm
    goto wait_for_commands
    not_arm_command: ' so check for 'off' command
    If buf(17)<>"5" then not_off_command
    If buf(18)<>"E" then not_off_command
    If buf(19)<>"5" then not_off_command
    Gosub alarm_off
    not_off_command:
    ' if we got here the command was not understood
    gosub error_comand
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. HELP ME, SMS controlled relay using PIC
    By pazko1125 in forum mel PIC BASIC
    Last Post: - 2nd October 2008, 16:26
  3. Siemens c55 sms control help please
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 20th August 2008, 02:13
  4. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  5. Need help on pic to pic flow control (simple problem I think)
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 01:34
