Build PIC bootloader firmware in PBP?
Results 1 to 4 of 4
    Mar 2006
    China
    Default It is possible
    What PIC are you using? I think it is easier to do this with a 18PIC since PBP handles the mamory allocation in a better way. I am in the middle of something similar but if you don't have a monster memory PIC i suggest you use one of the availible loaders in the market. My project is reading from a external eeeprom and writing to the flash memory... still far from finnished but it is allready almost 3000 words big. But we all know I2C eats code.....
    ASM is the way to go if you want a small Loader and there are may good ones out there.
    /me
    Jumper,
    Thanks for the reply.
    Actually, I am using an 18F part - the 18F2620. I already managed to modify a Mecanique MicroCode Studio loader by disassembling it, making the code changes, and reassembling it. It now works quite well for my purposes, using the PIC's internal 8MHz clock. The next thing I wanted to try was to modify the code so that there are 2 serial ports - the hardware port dedicated to the loader and a software port for my application. Once I do this, I hope to eliminate the need for a PIC reset in order to reload. I think I should be able to use the dedicated loader port to download new code any time I want to talk to it.
    Anyway, in musing about this, I thought it might be easier to do some of the things I wanted if the code was implemented in the PBP environment. However I do recognize that major sections of assembly code are unavoidable.
    Joe
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  3. Two PIC 16F877A fried in two days!
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 11:38
  4. can someone post example to code a bootloader using pbp?
    By nimonia in forum mel PIC BASIC Pro
    Last Post: - 9th May 2005, 17:28
  5. Using PBP Hex Files with FED Pic Programmer
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th February 2005, 11:57
