18F2620 compile problems in PBP
Results 1 to 10 of 10
    Sep 2005
    Campbell, CA
    If it works like the 8722, when you load the bootloader in the chip, you can set the config fuses so that the PLL is enabled. The 1Mhz default will be multiplied by 4, giving you the 4Mhz you want.
    Charles Linquist
    The MCS boot-loader firmware has config fuse options already set. You cannot over-ride these when loading your code into the target using the boot-loader software.
    I.E. whatever the config fuse settings are in the loader firmware you're stuck with.
    The only way to change config fuse settings, when using the MCS boot-loader, is to re-program the PIC with a different boot-loader firmware file.
    Whatever config fuse settings you may have embedded in your .hex file at compile time are simply ignored when you load your code using the boot-loader software. The boot-loading process does not alter config fuse settings.
    Note: The MCS boot-loader works only with an external oscillator. If you change this in the loader firmware before programming, it probably isn't going to work. At least not reliably.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Quote Originally Posted by Bruce
    ......Note: The MCS boot-loader works only with an external oscillator. If you change this in the loader firmware before programming, it probably isn't going to work. At least not reliably.
    Bruce,
    Why so? Why can't I write a loader that uses the internal clock? It certainly can't be an accuracy/stability issue - I have thousands of units in the field for a couple of years running serial comms with the internal clock over very wide temperature ranges. That much works fine.
    And if I CAN write a loader that uses the internal clock, then why can't I modify the MCS loader to do the same by disassembling, modifying, and reassembling?
    Joe
    Hi Joe,
    You can modify the MCS loader files if you like. They just won't work as-is
    with the internal oscillator.
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    I over-rode the bootloader config settings.
    I use the Microchip ICD2 to program the bootloader into the device. If you first load the proper bootloader file, you can then change the configuration fuse settings in the ICD2 "config" section. Program the part, and away you go.
    I have programmed several 18F8722s that had no external oscillator whatsoever. I simply set the "PLL ENABLED" and "Internal OSC" options in MPLAB and programmed it with the 4Mhz bootloader. MCLoader had no trouble at all loading my program files.
    Charles Linquist
    Thanks for the helpful suggestion Charles. It's always great to hear waht CAN be done instead of what CAN't be done
    Joe
  1. PBP v2.60 upgrade: MCSP compile issue
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 20:49
  2. PBP 2.50 UPGRADE problems!!!!
    Last Post: - 7th March 2008, 16:42
  3. Compile problems
    By ffindog in forum mel PIC BASIC Pro
    Last Post: - 25th June 2007, 03:51
  4. need 18F4550.BAS to compile with PBP?
    By jocovo in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2006, 02:23
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
