Need help Temp and 7segment led display
Results 1 to 9 of 9
    mastero's Avatar
    mastero Guest
    Quote Originally Posted by Darrel Taylor
    That's what I get for making a quick reply from work.
    After looking again, it appears that your program is written for Proton.
    Are you sure you're using PicBasic Pro?
    If so then yes to your interrupt question.
    If not, then you might want to try this forum.
    http://www.picbasic.org/forum/
    Now i am confused here
    Will check and let you know
    Don't worry Darrel.. there's a mix of 2 PICBASIC compiler in there...
    DEVICE 16F72
    not valid in PBP neither in PROTON
    DEFINE osc 4 ' 4 MHz oscillator
    DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
    PBP
    Dim digit As Byte 'input variable for GETMASK subroutine
    Proton
    PAUSE 250 ' Wait .5 second
    PBP native but now accepted by PROTON with a warning... well the last time i used it
    Now Mastero is on PROTON forum with the same code...
    mastero's Avatar
    mastero Guest
    Quote Originally Posted by mister_e
    DEVICE 16F72
    PBP
    Proton
    Yes its proton i am using.
    Cheers
    Mastero
