Need help Temp and 7segment led display
Results 1 to 9 of 9
    mastero's Avatar
    mastero Guest
    Default Need help Temp and 7segment led display
    Hello all,
    I am having difficulty in a project which i am working on.
    I require temperature reading on two 7 segement LED display.
    Using 16f72 and LM34 as sensor
    Does anyone know of a program which will read the temp from LM34 and display it on two LED segment display something like this
    h**p://www.geocities.com/hagtronics/thermometer.html
    I can program the LM34 to read temp and display on LCD but not 7 segment LED display.
    Anyhelp is good
    Cheers
    Mastero
    Check out the 7segment.pbp sample program at meLabs
    http://www.melabs.com/resources/samples.htm
    HTH,
      Darrel
    mastero's Avatar
    mastero Guest
    I have already checked it out and others.. the problem is putting the temp reading on LED
    DEVICE 16F72
    DEFINE osc 4 ' 4 MHz oscillator
    DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
    Dim digit As Byte 'input variable for GETMASK subroutine
    Dim digit1 As Byte 'current digit1
    Dim digit2 As Byte 'current digit2
    Dim mask As Byte 'output variable from GETMASK subroutine
    Dim mask1 As Byte 'current digit1 mask
    Dim mask2 As Byte 'current digit2 mask
    Dim temp As Word 'Temperature storage
    Dim samples As WORD ' Multiple A/D sample accumulator
    Dim sample As BYTE ' Holds number of samples to take
    Symbol d1enable = PORTC.7 'enable line for display1
    Symbol d2enable = PORTC.6 'enable line for display2
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00000011 ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
    TRISB = %00000000 'set PORTB pins as outputs
    TRISC.7 = 0 'set RD4 pin as output
    TRISC.6 = 0 'set RD5 pin as output
    LOW d1enable
    LOW d2enable
    mask1 = 0 ' Clear samples accumulator on power-up
    mask2 = 0 ' Clear samples accumulator on power-up
    samples = 0 ' Clear samples accumulator on power-up
    PAUSE 250 ' Wait .5 second
    loop:
    FOR sample = 1 TO 20 ' Take 20 samples
    ADCIN 0, temp ' Read channel 0 into temp variable
    samples = samples + temp ' Accumulate 20 samples
    PAUSE 250 ' Wait approximately 1/4 seconds per loop
    NEXT sample
    temp = samples/20
    digit1 = temp / 10 'get current digit1
    temp = temp // 10
    digit2 = temp 'get current digit2
    digit = digit1
    Gosub getmask 'get mask for digit1
    mask1 = mask
    digit = digit2
    Gosub getmask 'get mask for digit2
    mask2 = mask
    Gosub show1 'display new mask
    Gosub show2 'display new mask
    samples = 0 ' Clear old sample accumulator
    Goto loop
    getmask: 'get appropriate 7-segment mask for input digit
    mask = Lookupl digit,[$40,$79,$24,$30,$19,$12,$02,$78,$00,$18], digit
    show1: 'show digit1 on its display
    LOW d1enable
    LOW d2enable
    PORTB = mask1
    HIGH d1enable
    show2: 'show digit2 on its display
    LOW d1enable
    LOW d2enable
    PORTB = mask2
    HIGH d2enable
    Someone please check the above and let me know if there is any errors...?
    Cheers
    Mastero
    Well, this is a problem
    Try this instead ...
    Lookup digit,[$40,$79,$24,$30,$19,$12,$02,$78,$00,$18], mask
    HTH
    P.S. You'll need to speed up the loop for it to display properly.
    mastero's Avatar
    mastero Guest
    Is there a way i can have this whole process of reading the temp and displaying on the LEDs working in the background ? and the PIC is executing other commands.
    Will HPWM work here as i have one ccp pin on 16f72
    Thanks for your help
    Mastero
    That's what I get for making a quick reply from work.
    After looking again, it appears that your program is written for Proton.
    Are you sure you're using PicBasic Pro?
    If so then yes to your interrupt question.
    If not, then you might want to try this forum.
    http://www.picbasic.org/forum/
    mastero's Avatar
    mastero Guest
    Quote Originally Posted by Darrel Taylor
    Now i am confused here
    Will check and let you know
    Don't worry Darrel.. there's a mix of 2 PICBASIC compiler in there...
    DEVICE 16F72
    not valid in PBP neither in PROTON
    PBP
    Proton
    PBP native but now accepted by PROTON with a warning... well the last time i used it
    Now Mastero is on PROTON forum with the same code...
    mastero's Avatar
    mastero Guest
    Quote Originally Posted by mister_e
    DEVICE 16F72
    PBP
    Proton
    Yes its proton i am using.
    Cheers
    Mastero
