Can you give varied levels of priority to blocks of code?
Results 1 to 8 of 8
    Question Can you give varied levels of priority to blocks of code?
    Hi everyone, I am a real green newbie, first thing I want to do is thank everyone here for thier participation, I have already learned a ton from reading your posts...
    What I am trying to do is have a program set up with several blocks of code under several labels ( I have this already and it works) what I need to do is give each labeled block a priority level so they will run ahead of the lower priority if both or several are called by outside input, say a switch or button.
    Is this do able with a PIC?
    Joe Stokes
    This is usually what interrupts are for... to interrupt what the PIC is doing at any point in time and go service some task of greater priority and then on completion to resume what was previously interrupted.
    Default Priority to code blocks
    Hi Melanie!
    Ya I understand about interupts, that is not really my question,
    let's suppose we have a program which executes 4 strings to an lcd, each associated to a button or switch, just for clarity I will give them the following labels, FIRE:
    CLOSING TIME:
    RESTROOMS CLOSED:
    LAST CALL:
    This might be a sign in a Pub or Bar.
    The obvious first priority would be , FIRE, likely followed by Restrooms Closed . . etc . . .
    What I need is for FIRE to cancel and interrupt all lower displays, and Restroom Closed to Interrupt Last call without being able to interrupt FIRE and so on. . . Is this something a PIC can do?
    Thank You,
    Joe Stokes
    HERE IS AN EXMPLE OF MY CODE
    '* Name : Barsign.BAS *
    '* Author : [Joe Stokes] *
    '* Notice : Copyright (c) 2006 [JOE STOKES] *
    '* : All Rights Reserved *
    '* Date : 8/5/06 *
    '* Version : 1.0 *
    '* Notes : *
    CMCON=7 ' DISABLE ANALOG ON 628A.............................................. ..............
    INCLUDE "modedefs.bas"
    input 0
    input 1
    input 2
    input 3
    input 4
    input 5
    input 6
    output 7
    serout 7,N2400,[254,1,"?c0"] 'Sets curser to off . . Anderson Backpack
    pause 300
    serout 7,N2400,[254,1,"?f?a"] ' special initialization for Anderson Backpack
    ' sets curser to beginning of row 1
    pause 3500 ' give lcd time to initalize after clear
    serout 7,N2400,[254,1,"WELCOME TO MY PUB"]
    pause 2000 ' WAIT 2 SECONDS BEFORE START
    serout 7,N2400,[254,1,"?f?a"] ' RESET LCD
    goto start ' FINALLY PROGRAM STARTS
    start:
    'CHECKS STATUS RESTROOMS AND REPORTS TO PATRONS ON LCD
    RESTROOM:
    WHILE PortB.4 = 1
    pause 250
    SEROUT 7,N2400, [254,1,"RESTROOMS ARE CLOSED"]
    PAUSE 3000
    clear
    WEND
    'CHECKS STATUS OF FIRE ALARM AND REPORTS TO PATRONS ON LCD
    FIRE:
    WHILE PortB.5 = 1
    pause 250
    SEROUT 7,N2400, [254,1,"FIRE, PLEASE EVACUATE"]
    pause 3000
    clear
    WEND
    'CHECKS STATUS OF LAST CALL AND REPORTS TO PATRONS ON LCD
    LAST_CALL:
    WHILE PortA.1 = 1
    pause 250
    SEROUT 7,N2400, [254,1, "LAST CALL FOR ALCOHOL, SOON ONLY COFFEE SERVED!"]
    'SEROUT 7,N2400,[254,192,]
    pause 3000
    clear
    WEND
    'CHECKS STATUS OF CLOSING TIME AND REPORTS TO PATRONS ON LCD
    CLOSING:
    WHILE PortB.0 = 1
    pause 250
    serout 7,N2400,[254,1,"CLOSING TIME THANK YOU AND GOODNIGHT!"]
    PAUSE 3000
    clear
    WEND
    GOTO START
    i am thinking If fire = 1 then start
    IF restroom = 1 then start
    and then somehow use some and statements to call interrupts
    or exclude them . . .
    as Daniel Boone once said" I've never been lost, but I've been a might
    bewildered . ."
    Thanks ,
    Joe
    May 2006
    Del Rio, TX, USA
    Hi Joe,
    Try something like this:
    input 0
    input 1
    input 2
    input 3
    input 4
    input 5
    input 6
    output 7
    FIRE_PIN      VAR PortB.5
    RESTROOM_PIN  VAR PortB.4
    LAST_CALL_PIN VAR PortA.1
    CLOSING_PIN   VAR PortB.0
    GOTO START
    '---------- Subroutines ------------------
    '---=== Initialize LCD LCD  ===---
    INIT_LCD:
       pause 300
    '---=== Reports status of RESTROOM to partons on LCD  ===---
    RESTROOM:
       pause 250
       PAUSE 3000
    '---=== Reports status of FIRE to partons on LCD  ===---
    FIRE:
       pause 250
       pause 3000
    '---=== Reports status of LAST_CALL to partons on LCD  ===---
    LAST_CALL:
       pause 250
       pause 3000
    '---=== Reports status of CLOSING to partons on LCD  ===---
    CLOSING:
       pause 250
       PAUSE 3000
    '---=== GREETING to partons on LCD  ===---
    GREETING:
       pause 250
       PAUSE 3000
    '---------- Main Program Code ------------
    START:
       GOSUB INIT_LCD
       GOSUB GREETING
    MAIN:
       IF FIRE_PIN = 1 THEN
          GOSUB FIRE
          IF RESTROOM_PIN = 1 THEN
             GOSUB RESTROOM
             IF LAST_CALL_PIN = 1 THEN
                GOSUB LAST_CALL
             ELsE
                IF CLOSING_PIN = 1 THEN
    		GOSUB CLOSING
                    GOSUB GREETING
       PAUSE 1000
    GOTO MAIN
    I did not make any changes to the actual code lines you have, but did rearrange them into subroutines that could be called by nested IF...THEN...ELSE...ENDIF statements. This provides the priority levels you wanted. The first IF...THEN that is true will execute and then jump over the subsequent code in the ELSE portion of the statement. Additionally, I added a 5th option (GREETING) if none of the other conditions are true. You can change around the priority any way you want. Also note that I assigned names to the pins to make them easier to understand later on in the code. I haven't access to my compiler right now, so I haven't "run" my version, it isn't bug tested. Also, I am sure there are more ways to "skin this cat" but this is a start.
    EDIT: Got access to my PBP, and it compiled without errors, so you just need to check it out on you equipment.
    HTH,
    Smile That Simple?
    HI STEVE B.
    Wow that is very close to my first try which I could not get to work I had used button commands and IF THEN statements and included an ENDIF statment within the subroutine, I see you put them all at near the end of program, I am curious about the indenting you used, is it there so you the programmer can keep it straight in your mind or does it affect the program in some way?
    Anyway I want to thank you and Melanie for your help, I really appreciate it!
    I hope to be helpful to someone else someday!
    Best Regards
    Joe Stokes
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Making Program Code Space your playground...
  3. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
  4. Still HSEROUT woes
    Last Post: - 11th July 2006, 21:13
  5. Timer PIC16F57
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 08:14
