Matching PIC memory and program size?
Results 1 to 9 of 9
    Isle of Man
    Cool Matching PIC memory and program size?
    I need help in understanding how to select a PIC with the flash program memory size to accommodate my PBP-compiled programs.
    For example, Microcode Studio tells me that one of my small programs for the 16F877 compiles to 377 words, while Windows Explorer gives the HEX file size as 2.14K. Once the project is completed, I want to choose a device with minimal size and cost to fit the code.
    In general, how do you understand each of these memory sizes, and then choose a suitable PIC device?
    Sep 2005
    Campbell, CA
    The number you get from Microcode Studio is the more accurate. The .HEX file is in Intel Hex format, which is an ASCII representation of the binary source.
    A 512 byte or 1K byte PIC should easily hold your code.
    If you want to find out what that .HEX file really contains (as well as the load addresses of the code), you can decode the .HEX file according to the rules given at:
    www.cs.net/lucid/intel.htm
    Charles Linquist
    Isle of Man
    Thanks for the clues, Charles.
    However, I am still a little bit confused. For example, suppose I change to a 16F676, which the data sheet says has "1024 Flash Words" of program space. Do these WORDS equate with the WORDS given by Microcode Studio?
    It is a pity that this is not properly explained in any of the MCS or PBP documentation and that MCS (or my MEL chip programmer) does not give the % space remaining or used in the device selected.
    Jan 2006
    Istanbul
    Smile
    Quote Originally Posted by manxman
    Yes, pls refer to the picture.
    The word size of a PIC should match (or stay lower) then the word size that your compiler compiles for you.
    Isle of Man
    Cool PIC Program size
    Many thanks Sayzer and Charles for the final WORD (!). All clear now. I can now program a device until it (almost) bursts.
    Corona's Avatar
    Corona Guest
    Quote Originally Posted by Sayzer
    Methinks you mean the capacity of the PIC should be HIGHER than the compiled code size...in words
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Making Program Code Space your playground...
  3. Which pic has a big flash program memory?
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 20:35
  4. program memory size
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 20:45
  5. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 18:23
