FOR sequence is skipped
Results 1 to 5 of 5
    In a world of german electrons
    Angry FOR sequence is skipped
    Hello. I wrote this piece of code to test PBP:
    Start:
    	YellowLED VAR PORTB.0
    	RedLED VAR PORTB.1
            t VAR BYTE
    	WH VAR BYTE
    	High  CMCON.0
    	High  CMCON.1
    	High  CMCON.2
    	HIGH  STATUS.0
    	TRISB = %00000000
    	TRISA = %00000000
    	Low  STATUS.0
    	High  YellowLED 	;LED Starting sequence
    	High  RedLED
    	PAUSE  2000
    	Low  YellowLED
    	Low  RedLED
    	PAUSE  2000
    	FOR	t=20000 TO 250 STEP - 1
     		High 	RedLED
    		PAUSE 	100
     			FOR	WH=0 TO 2000 STEP 1
    		 	PAUSE  20
    		 	High 	YellowLED
    			PAUSE	100
    			Low 	YellowLED
    		NEXT WH
    		Low 	RedLED
    	NEXT t
    GO:
    	High  RedLED
    	High  YellowLED
    	PAUSE  500
    	Low  RedLED
    	Low  YellowLED
    	PAUSE  500
    	GOTO  GO
    Unfortunately it acts as if there is no "FOR" present. So what it does is the following:
    Start:
    	RedLED VAR PORTB.1
            t VAR BYTE
    	WH VAR BYTE
    	High  CMCON.0
    	High  CMCON.1
    	High  CMCON.2
    	HIGH  STATUS.0
    	TRISB = %00000000
    	TRISA = %00000000
    	Low  STATUS.0
    	High  RedLED
    	PAUSE  2000
    	Low  YellowLED
    	Low  RedLED
    	PAUSE  2000
    GO:
    	High  RedLED
    	High  YellowLED
    	PAUSE  500
    	Low  RedLED
    	Low  YellowLED
    	PAUSE  500
    	GOTO  GO
    How to solve this ?
    Jul 2005
    Midwest
    try making t and wh word sized variables
    it works thank you
    Jan 2006
    Istanbul
    Inn addition to Steve's,
    also consider this:
    FOR t=2000 TO 25 STEP - 1
    next t
    Okay. Thank you.
