Recording WAV files to EEPROM
Results 1 to 5 of 5
    Cambridge UK
    HI Luciano,
    Thanks for the link to that data sheet, its a bit complicated for me at the moment. I would like to stick with pbp for the moment.
    Have been searching this site again and ISD4002 looks like a good bet.
    Before I was using the ISD1200 series which was easy to set up but a pain for me to load the audio too, and then address each sample.
    Going to study the ISD4002 data sheet and see if I can get better results this time, If any one has any tips for these chips please let me know.
    Kind regards
    Nick
    do a search for ISD4002 in this forum... there's some example here and there
    Cambridge UK
    Hi mister e
    Have done a few searches on here for isd4002, found some good links, I have down loaded and printed the data sheet and a example program from melabs for their lab-xt board.
    http://www.melabs.com/resources/samples.htm#xtpbp
    Goto the voicext.bas full code given, I am going through it so I understand how it works, I will then attempt to modify it for the pic16f628.
    Its going to be a bit slow, I am refering to the data sheet, pbp manual and
    sample prog! Will let you know how I get on, next i'll need to get hold of a isd4002 chip.
    Kind regards
    Nick
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 05:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
