CONFIG directive warning help
Results 1 to 4 of 4
    josegamez's Avatar
    josegamez Guest
    Question CONFIG directive warning help
    Hello. I`m currently working on a project at my university and it involves the use of a PIC. This is the first time that me and my lab partners have ever used PICs, but because of the nature of the project and our specific needs we were forced to choose a large and high speed PIC. So please excuse my ignorance but we never got a chance to start out with a simple PIC and we are in sort of a rush. We chose the PIC18lf458 because it had those characteristics and we are trying to use PICBasic Pro with MicroCode Studio IDE to make at least programming the PIC easier. However, since we are completely new to the PICs and PBP world we are experiencing some problems and we have some doubts. We tried to compile a simple program with an infinite loop that turns on and off a LED and we got this error message:
    MPASM Required
    The PICMicro Assembler does not support the 18F458 microcontroller. You need to use MPASM in order to compile your PICBasic program.
    So we installed MPLab and set the path in the "Compile and Program Options" Assembler dialogue and compilation seemed to complete successfully but we got these warning messages.
    Warning[230] c:\pbp246\18f458.inc 20:__CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    Warning[230] c:\pbp246\18f458.inc 21:__CONFIG has been deprecated for PIC18 devices. Use directive CONFIG
    Warning[230] c:\pbp246\18f458.inc 22:__CONFIG has been deprecated for PIC18 devices. Use directive CONFIG
    So we need help in fixing this problem to be able to compile without any warnings. To tell the truth I donīt even understand the warning so I don't know if its something serious or not. Thank you very much in advance for your time and help. God bless you.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    josegamez's Avatar
    josegamez Guest
    Smile Thanks!
    Thanks a lot Bruce! That warning made me feel uncomfortable because I didn't know if it wasn't going to work just because of it, now we can work peacefully
    You're welcome.
    FYI: You can disable this annoying warning by adding w = -230 to the default
    18f458.inc file in your PBP install directory.
    LIST p = 18F458, r = dec, w = -311, w = -230, f = inhx32
    MeLabs has updated all default 18F header files with this switch in the latest
    version. If you're using an older version of PBP (pre v2.47) just alter the .inc file.
    -Bruce
    tech at rentron.com
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
