Matching PIC memory and program size?
Results 1 to 9 of 9
    Corona's Avatar
    Corona Guest
    Quote Originally Posted by Sayzer
    The word size of a PIC should match (or stay lower) then the word size that your compiler compiles for you.
    Methinks you mean the capacity of the PIC should be HIGHER than the compiled code size...in words
    Jan 2006
    Istanbul
    Smile Looking at the mirror from the other side.
    Yes, actually I stated it from the other side.
    You are right Corona.
    PIC capacity should be higher.
    Corona's Avatar
    Corona Guest
    no problem
    I've found that soon after using the MIN / MAX PICBasic functions, I get confused over Up/Down Right/Wrong myself
    Jan 2006
    Istanbul
    Also take a look at this post here:
    Word sizes for the same code but for different PICs are also different.
    http://www.picbasic.co.uk/forum/showthread.php?t=3548
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Making Program Code Space your playground...
  3. Which pic has a big flash program memory?
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 19:35
  4. program memory size
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 19:45
  5. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 17:23
