Help with sending text file from pic
Results 1 to 7 of 7
    Hi Isaac,
    In Hyperterminal, goto
    File | Properties | Settings Tab |ASCII Setup
    and check the "Send line ends with line feeds" checkbox.
    brighton
    Thumbs up
    Thanks Darrel
    Your advice did the trick
    Isaac
    Docw's Avatar
    Docw Guest
    Default Sending text within quotes e.g. "xxxx" within a string
    Is it possible to send a string that has text within quotation marks in a string using the SEROUT command ? I seem to get an error and I need to use this feature to send commands to an external color LCD panel. (BTW, I'm new at PicBasic).
    Sure can,
    The ascii code for double quotes is 34. So you can do this...
    SEROUT Pin, Mode, [34,"some text here",34]
    Docw's Avatar
    Docw Guest
    Thank you !!! That approach had never occurred to me.
  1. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  2. Best way to store text in a pic
    By atwoz in forum General
    Last Post: - 6th December 2007, 15:50
  3. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 19:31
  4. Need help on pic to pic flow control (simple problem I think)
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 01:34
  5. Help, problems first time with 18F452 PIC
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 21:49
