Setting up 5 HPWM pins on 18F4680
Results 1 to 2 of 2
    Dec 2003
    San Diego
    Question Setting up 5 HPWM pins on 18F4680
    I need to setup 5 hardware PWM outputs on the PIC18F4680.
    Has anyone set these up as dedicated outputs that run in the background?
    I see the PB setup for HPWM 1, and 2 but not anything more that 2.
    Do I have to drop into assembly code to do this or are there defines that I can do that will allow me to just select HPWM 1, 2, 3, 4, and 5.
    The frequency of each output can be the same... only the duty cycle needs to vary from 0 to 100% on each pin.
    Tcbcats
    As far as i remind, this one have only 1 CCP module and hence, one PWM output but up to 4 if using the ECCP feature... wich will never solve your problem, all output are complementary (or something like that ). So you'll have to build a homebrew routine. A TIMER interrupt for the base frequency and play with the various duty cycles in the ISR.
    Kind of background. Look at the Darrel Taylor instant interrupt. Should be handy and work really great.
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  3. Problem setting pins on 12f675
    By srnet01 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 16:58
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
