Need help to shut off comparators for 16f688
Results 1 to 12 of 12
    jessey's Avatar
    jessey Guest
    Default Need help to shut off comparators for 16f688
    Hello,
    I'm trying to shut off the comparators on my 16f688 and can't seem to accomplish it, as a result I can't get RA0 or RA1 to function as expected. When I use CMCON0 = 7 or CMCON0 = %00000111 and try to compile, I get an error message saying there is a syntax error.
    I'm using PicBasic Pro Ver 2.45, MPASM Ver 3.60 with MicroCode Studio 2.1.0.7 and EPIC Version 2.46 beta programmer with a PIC16F688-20/P.
    Would anyone have any suggestions on why it won't compile? I looked at the data sheet and CMCON0 = %00000111 is a valid command and I've also seen this used in code examples while looking in the archives.
    Any help would be very much appreciated.
    jessey
    Default A long shot
    Hi Jessy,
    Do you have the right chip selected in MicroCodeStudio?
    I believe you also need to clear the corresponding bits in the ANSEL register to make the pins digital.
    /Henrik Olsson.
    jessey's Avatar
    jessey Guest
    Hi Henrik,
    Thanks for your reply. Yes I have selected the 16f688 in the MicroCode Studio drop down list and I'm also using ANSEL = %00000000.
    Any other ideas?
    jessey
    Jun 2006
    Quote Originally Posted by jessey
    use : CMCON = 7
    jessey's Avatar
    jessey Guest
    Hi savnik,
    When I try and compile using CMCON = 7 I get an error saying 'Symbol not previously defined (CMCON)'. I checked the data sheet and the only reference it makes to CMCON is in a, Modified Comparator C1 Output Block Diagram in figure 7-4 and 7-5.
    jessey
    Hi Jessey,
    I have both PBP 2.45 and 2.46
    In 2.45 I get the same error you described. With 2.46 I don't.
    But without upgrading, you might try
    POKE $19, 7
    HTH,
    jessey's Avatar
    jessey Guest
    Default Works like a charm
    Hi Darrel,
    That's great, it works like a charm now. I'll have to upgrade to the newest version. I'm in your debt once again.
    Thanks a million
    jessey
    Thumbs up
    No need to be in debt.
  1. Using Comparators
    By Short_Circuit in forum Code Examples
    Last Post: - 25th November 2009, 13:57
  2. Comparators on 18F4520
    By RacerX10 in forum mel PIC BASIC Pro
    Last Post: - 27th August 2009, 23:33
  3. Comparators - like descrite components?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 9th October 2007, 18:17
  4. I shut this guy down
    By T.Jackson in forum Off Topic
    Last Post: - 25th May 2007, 03:27
  5. 16F88 using comparators AND the adc
    By jpeakall in forum mel PIC BASIC Pro
    Last Post: - 13th May 2005, 01:08
