DS1307 automotive application
Results 1 to 11 of 11
    Jun 2005
    Wisconsin
    Default DS1307 automotive application
    I'm using the DS1307 in an automotive application. In the datasheet the RTC backup is a 3V coin battery. Since the vehicle as a battery would it make sense to use it in place of the coin battery? If so all I should need to do is swap out the battery for a voltage regulator?
    Feb 2003
    I would still use a coin cell.
    The voltage regulator will use far more current than the RTC itself and if the car battery gets disconnected then the RTC will stop.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jun 2005
    Wisconsin
    My concern is more space related. The coin cell holder eats up valuable board space.
    Bombay, India
    How about using an electrolytic backup instead of the coin cell. Thus, even if the battery is disconnected for a few minutes, the RTC still works. You could work out the value of the capacitor based on the amount of time you need it to hold while the car battery is disconnected. Of course, you still need to charge the cap while the battery is connected.
    Jerson
    Jun 2005
    Wisconsin
    I’m not worried about losing the time when the battery is removed. If you remove the battery in your personal vehicle, you have to reset all the clocks. People are used to this fact, I think.
    A voltage Regulator is probably overkill. A 3.3v Zener in series with a Resistor should suffice. Zeners are noisy, so a small Capacitor across it would keep the RTC happy, but you might not even need it. Actually, if you made it something like a 1uF, it probably would have enough charge to keep the RTC Backed-Up for an hour or more.
    Jun 2005
    Wisconsin
    "A 3.3v Zener in series with a Resistor should suffice."
    In series?
    You should want to put it in parallel? A 3.3v Zener directly across a 12v car Battery is something you will only try once - Don't hold the Zener in your fingers when you do it!
    Jun 2005
    Wisconsin
    So to recap:
    12V (battery) --> Resistor --> Zener K--> 1uF Cap --> DS1307
    Both the Zener Anode and Cap get tied to Common.
    Yes, I think you've got it...
    Jun 2005
    Wisconsin
    Oh sure one up me with a picture.
    Yeah thats what I had, we are both on the same page.
  1. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 12:55
  2. DS1307 12-hour mode with AM/PM divisor
    By JNOR07 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2007, 14:26
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. Connecting DS1307 to PIC16F877A
    By amindzo in forum General
    Last Post: - 8th September 2006, 15:11
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
