so you should, once again, open the datasheet in the SLEEP section first.
Have a look at section 14.8 Power-down mode and section 14.8.1 Wake-up from sleep. There, you will discover what can wake-up your PIC
External RESET
Watchdog timer
Interrupt from RB0/INT pin, interrupt on some PORTB pins or peripheral interrupts (comparator, USART... )
without some change to your hardware... i doubt you'll be able to wake your PIC ONLY if you change some dip switch.
to turn your PIC in sleep mode only for 5 secondes, you may have a look in the PBP book at SLEEP section.
SLEEP 5
