DipSwitch
Results 1 to 17 of 17
Thread: DipSwitch
    Jun 2006
    Default DipSwitch
    I have this code below to control the TSA5511 for a PLL for FM (87-108MHZ)
    DEFINE I2C_SCLOUT 1
    SYMBOL SDA=PORTA.0
    SYMBOL SCL=PORTA.1
    SYMBOL DIP1=PORTB.7
    SYMBOL DIP2=PORTB.6
    SYMBOL DIP3=PORTB.5
    SYMBOL DIP4=PORTB.4
    SYMBOL DIP5=PORTA.2
    SYMBOL DIP6=PORTA.3
    SYMBOL DIP7=PORTB.3
    SYMBOL DIP8=PORTB.2
    SYMBOL DIP9=PORTB.1
    SYMBOL DIP10=PORTB.0
    ADDR1 VAR BYTE
    TMP VAR WORD
    PLLBASE VAR WORD
    PLL VAR WORD
    LO VAR PLL.LOWBYTE
    HI VAR PLL.HIGHBYTE
    INPUT DIP1
    INPUT DIP2
    INPUT DIP3
    INPUT DIP4
    INPUT DIP5
    INPUT DIP6
    INPUT DIP7
    INPUT DIP8
    INPUT DIP9
    INPUT DIP10
    OUTPUT SCL
    OUTPUT SDA
    The PIC is 16f84a and xtal = 4MHZ
    Because i want to add dipswitch , may use the RA4 as input.
    If i use the 16f628a how to configure , to add 4 dipswitch more.
    Jun 2006
    any help ;
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I have read your question now a couple of times and it is not clear (at least to me) what you are asking.
    Are you wanting to get rid of your XTAL to gain more input lines? If you do, with the use of RA4 you will have 3 more but have requested 4. Please clarify your request.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jun 2006
    Quote Originally Posted by paul borgmeier
    I now use 10 dipswitch as input (look at image) and i want to add more dipswitch.
    Can i use the pin which are for the xtal (ra6-ra7) as input , if i use the pic16f628.
    also the ra4 and the mclr(ra5).
    will i have problem if change the XTAL with internal OSC;
    Sorry for my English.
    you shouldn't have too much problem using the internal OSC as your application (for what i remind of) is not really timing critical. Go Go Go use the internal OSC and the MCLR pin as you wish, they're free!
    The only thing you'll have to do is to change the config fuse.. see the FAQ
    You don't want to hear my Greek My english is actually really poor myself too but who cares as long as somebody understand it
    Jun 2006
    Quote Originally Posted by mister_e
    Thank you for your answer.
    i need to use this;
    @ DEVICE pic16F628a, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16F628a, MCLR_OFF
    May i use the RA4 as input;
    Do you speak greek(ellinika);
    Yes you can use Ra4 as input.
    No i don't speek Greek... i may understand few words here and there but... yiissh.. hehe as the english expression said ... it's Greek to me Quebecer french says... it's Chinese to me... i heard also something like It's Gobledagook to me. I guess it depend where you're located.
    I speak French (native language) and a sort of English with few mistakes
    Jun 2006
    Thank you again for help
    I live in Lesvos(Island)
    i hope i found the right thing...
    παρακαλώ!
    Jun 2006
    παρακαλώ!
    yes , is the right answer
    Jun 2006
    Quote Originally Posted by savnik
    DEFINE I2C_SCLOUT 1
    SYMBOL SDA=PORTA.0
    SYMBOL SCL=PORTA.1
    SYMBOL DIP1=PORTB.7
    SYMBOL DIP2=PORTB.6
    SYMBOL DIP3=PORTB.5
    SYMBOL DIP4=PORTB.4
    SYMBOL DIP5=PORTA.2
    SYMBOL DIP6=PORTA.3
    SYMBOL DIP7=PORTB.3
    SYMBOL DIP8=PORTB.2
    SYMBOL DIP9=PORTB.1
    ADDR1 VAR BYTE
    TMP VAR WORD
    PLLBASE VAR WORD
    PLL VAR WORD
    LO VAR PLL.LOWBYTE
    HI VAR PLL.HIGHBYTE
    INPUT DIP1
    INPUT DIP2
    INPUT DIP3
    INPUT DIP4
    INPUT DIP5
    INPUT DIP6
    INPUT DIP7
    INPUT DIP8
    INPUT DIP9
    INPUT DIP10
    OUTPUT SCL
    OUTPUT SDA
    I want after set the frequency with the dip switch the PIC to go to sleep until i change the frequency again with the dip switch.
    I want the PIC to go to sleep after about five seconds.
    But i don't know how.
    Hangover, Germany
    Using such a lot of switches....
    you should read the articles who use a analog-port to read 4-7 switches !!!
    Sleeping:
    You have to use a timer to awake (!), because, there is no interrupt covering all your switches.
    So you have to save the switches in your RAM, set a timer to wait a time (prescaler, postscaler, ...) to wake up, enable the neccessary interrupts and go sleep. The interrupt will wake up the PIC at the next position (imho) and you have to check, if any switch has been moved.
    Loop !
    Jun 2006
    Quote Originally Posted by BigWumpus
    Sleeping:
    Loop !
    I have change the code
    @ DEVICE pic16F628a, INTRC_OSC_NOCLKOUT     ' System Clock Options
    @ DEVICE pic16F628a, MCLR_OFF	            ' Master Clear Options (Internal)
    CMCON = 7               ' PortA = digital I/O
    DEFINE I2C_SCLOUT 1
    SYMBOL SDA=PORTA.0      ' SDA  var  PORTA.0
    SYMBOL SCL=PORTA.1      ' SCL  var  PORTA.1
    SYMBOL DIP1=PORTB.7
    SYMBOL DIP2=PORTB.6
    SYMBOL DIP3=PORTB.5
    SYMBOL DIP4=PORTB.4
    SYMBOL DIP5=PORTA.6
    SYMBOL DIP6=PORTA.7
    SYMBOL DIP7=PORTA.2
    SYMBOL DIP8=PORTA.3
    SYMBOL DIP9=PORTA.4
    SYMBOL DIP10=PORTA.5
    SYMBOL DIP11=PORTB.3
    SYMBOL DIP12=PORTB.2
    SYMBOL DIP13=PORTB.1
    SYMBOL DIP14=PORTB.0
    ADDR1 	VAR BYTE
    TMP   	VAR WORD
    PLL   	VAR WORD
    LO    	VAR PLL.LOWBYTE
    HI    	VAR PLL.HIGHBYTE
    INPUT DIP1
    INPUT DIP2
    INPUT DIP3
    INPUT DIP4
    INPUT DIP5
    INPUT DIP6
    INPUT DIP7
    INPUT DIP8
    INPUT DIP9
    INPUT DIP10
    INPUT DIP11
    INPUT DIP12
    INPUT DIP13
    INPUT DIP14
    OUTPUT SCL
    OUTPUT SDA
    ADDR1=$C2
    Never use interrupt and i don't how
    so you should, once again, open the datasheet in the SLEEP section first.
    Have a look at section 14.8 Power-down mode and section 14.8.1 Wake-up from sleep. There, you will discover what can wake-up your PIC
    External RESET
    Watchdog timer
    Interrupt from RB0/INT pin, interrupt on some PORTB pins or peripheral interrupts (comparator, USART... )
    without some change to your hardware... i doubt you'll be able to wake your PIC ONLY if you change some dip switch.
    to turn your PIC in sleep mode only for 5 secondes, you may have a look in the PBP book at SLEEP section.
    SLEEP 5
    Jun 2006
    External RESET
    Watchdog timer
    SLEEP 5
    I have read datasheet many times.(I don't understand datasheet very well because i don't know english very well)
    I want to wake PIC ONLY if i change one or some dip switch and after 5 seconds to go to sleep again , until if i change one or some dip switch again.
    But i don't know how to write the code.
    Jan 2006
    Istanbul
    ....(I don't understand datasheet very well because i don't know english very well).....
    Hi savnik,
    Since you know the difference of using "well" instead of "good", your English seemed very well to me!
  1. PIN state VS Variable read
    By cburtis in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 12:54
  2. Dipswitch matrix
    By DynamoBen in forum Off Topic
    Last Post: - 8th October 2007, 18:11
