A/D conversion problem with pic16F88
Results 1 to 10 of 10
    Tapio Linkosalo's Avatar
    Tapio Linkosalo Guest
    Ok, tried increasing the acquisition time up to 1000us - no help. Then checked the voltage with PC-scope. Input voltage to PIC is stable (also used as Vref), and the ripple on the output from op.amp. is just a few percent, nothing like the error readings in the AD. Still looks like there is a configuration problem in my software?
    Hi,Tapio
    Could also come from an unwanted 10 to 8 Bits truncature ( indexed EEPROM transfer bug i.e. )... I do not see why, but it is possible ... so, to be checked !!! .
    Alain.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Tapio,
    Another thing to try ....
    Remove the thermocouple input from RA2 and replace it with a known voltage input (from a voltage divider or pot). With this, you should be able to determine if the problem is from the software side or the hardware side. Just a thought ...
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Alain,
    truncation is a possibility that came also to my mind. I tried adding "define adcbits 10" to the software yesterday, at that time it started to work, but it could be also that re-soldering one lead of the thermocouple at the same time was the real reason. I tried to remove the define, even erase the chip and reprogram in case that the define did a change in the configuration that was not reversable by removing it, but could not return to the erraneous state of affairs.
    I wonder if the reason could be in the input. I checked the output from the op. amp. with oscilloscope, and it seems to be stable within around 5%, nothing like 4-fold variation in the input values.
    Smile
    Hi, Tapio
    Glad to hear it works ...
    As the Define Adcbits deal with adcin ... I'd bet the thermocouple was the trustable reason ...
    Actually, it did not work, but now I think it does.
    The problem was not in the A/D configuration, but the op-amp. The datasheets tell to add a resistor for bias current return path which I had not added (and also had to tinkle around as ref ground and opamp power ground must be different). So the erronous readings were due to thermocouple drifting towards V+ref end of the input.
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem with 18F2455
    By abdy37 in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 15:53
  4. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
