2 variable
Results 1 to 3 of 3
Thread: 2 variable
    brighton
    Default 2 variable
    Hello All,
    Could someone be kind enough to help me in adding those 2 variables
    This is the story.
    I have got 2 variable Fint & Fdec, Fint contains the integer part of my result(16bits) while Fdec contains
    the decimal part of my result
    so to display a result of 2717.6Hz on an lcd i do the following assuming the variables already contain the following
    Fint = 2717
    Fdec = 6
    LCDout I, Line1,"Result = ",dec Fint ,".",dec Fdec,"Hz"
    Now i need to modify the result so that i can also display Frequency squared (2716.2)2 divided by 1000
    this means adding Fint & Fdec somehow to give 27176 then multply by itself before dividing using DIV32 to divide
    Its combining them that i find a bit stricky could anyone help
    Isaac
    This is your tricky bit solved...
    BigWord=(Fint*10)+Fdec
    Naturally, you cant have Fint bigger than 6552 to start with.
    Now to do some easy stuff like turning Gold into Lead...
    brighton
    Thumbs up
    Thanks Mel
    i really feel that i should have thought it through
    my max Fint would be 6000 so i should be ok
    Thanks for your help
    Isaac
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  5. Variable PWM on 2 Channels using software.
    Last Post: - 23rd September 2006, 02:34
